C891 encapsulation failed
Trying to setup soho internet with C891 to Verizon ONT(FiOS) but receiving encapsulation failed in debug ip packet.
Config and debug log below:
version 15.3
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp pool InsideDHCP
 import all
 network 192.168.1.0 255.255.255.0
 default-router 192.168.1.1
 dns-server 8.8.8.8 8.8.4.4
! class any
vpdn enable
vpdn-group 1
vpdn-group pppoe
interface FastEthernet0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0
 switchport access vlan 10
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 ip address dhcp
 duplex auto
 speed auto
 pppoe enable
 pppoe-client dial-pool-number 1
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip nat inside
 ip virtual-reassembly in
 ip tcp adjust-mss 1452
interface Async3
 no ip address
 encapsulation slip
interface Dialer1
 ip address dhcp client-id GigabitEthernet8
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1452
 ip flow ingress
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp authentication chap pap callin
 ppp chap hostname guest
 ppp chap password 7 040A0D0F1DF05155C
 ppp pap sent-username guest password 7 0055150FC07032D15
 no cdp enable
ip nat inside source list 10 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 10 permit 0.0.0.0 255.255.255.0
sh ip int br output:
Interface                  IP-Address      OK? Method Status                Protocol
Async3                     unassigned      YES unset  down                  down
BRI0                       unassigned      YES unset  administratively down down
BRI0:1                     unassigned      YES unset  administratively down down
BRI0:2                     unassigned      YES unset  administratively down down
FastEthernet0              unassigned      YES unset  administratively down down
GigabitEthernet0           unassigned      YES unset  up                    up
GigabitEthernet1           unassigned      YES unset  down                  down
GigabitEthernet2           unassigned      YES unset  down                  down
GigabitEthernet3           unassigned      YES unset  down                  down
GigabitEthernet4           unassigned      YES unset  down                  down
GigabitEthernet5           unassigned      YES unset  down                  down
GigabitEthernet6           unassigned      YES unset  down                  down
GigabitEthernet7           unassigned      YES unset  down                  down
GigabitEthernet8           108.18.151.203 YES DHCP   up                    up
NVI0                       108.18.151.203 YES unset  up                    up
Vlan1                      unassigned      YES unset  administratively down down
Vlan10                     192.168.1.1     YES manual up                    up
ping 108.18.151.1
Sending 5, 100-byte ICMP Echos to 108.18.151.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
debug ip packet output:
Mar 15 12:47:23 EDT: IP: s=108.18.151.203 (local), d=3.93.76.89 (Dialer1), len 84, output feature, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 15 12:47:23 EDT: IP: s=108.18.151.203 (local), d=3.93.76.89 (Dialer1), len 84, output feature, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 15 12:47:23 EDT: IP: s=108.18.151.203 (local), d=3.93.76.89 (Dialer1), len 84, output feature, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 15 12:47:23 EDT: IP: s=108.18.151.203 (local), d=3.93.76.89 (Dialer1), len 84, output feature, NAT ALG proxy(59), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 15 12:47:23 EDT: IP: s=108.18.151.203 (local), d=3.93.76.89 (Dialer1), len 84, output feature, Post-Ingress-NetFlow(74), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 15 12:47:23 EDT: IP: s=108.18.151.203 (local), d=3.93.76.89 (Dialer1), len 84, output feature, Dialer idle reset(93), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 15 12:47:23 EDT: IP: s=108.18.151.203 (local), d=3.93.76.89 (Dialer1), len 84, encapsulation failed
try the simplified config below (important parts marked in bold):
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip address dhcp
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
interface Async3
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet8 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet8 dhcp
access-list 10 permit 192.168.1.0 0.0.0.255
11 Replies 11
change access list 10 to:
updated ACL:
#sh ip access-list 10
Standard IP access list 10
    10 permit 192.168.1.0, wildcard bits 0.0.0.255 (124 matches)
    10 permit 192.168.1.0, wildcard bits 0.0.0.255 (126 matches)
    10 permit 192.168.1.0, wildcard bits 0.0.0.255 (127 matches)
but no change in access, not able to access internet.
NAT translations show none:
#sh ip nat translations
NAT statistics show:
#sh ip nat statistics
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 0
Outside interfaces:
  Dialer1
Inside interfaces:
  Vlan10
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list 10 interface Dialer0 refcount 0
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
Debug ip packet still shows encapsulation failed:
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255 (Vlan10), len 78, output feature, NAT Inside(8), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255 (Vlan10), len 78, output feature, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255 (Vlan10), len 78, output feature, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255 (Vlan10), len 78, rcvd 3
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, stop process pak for forus packet
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, enqueue feature, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, input feature, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, input feature, Virtual Fragment Reassembly(36), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, input feature, Virtual Fragment Reassembly After IPSec Decryption(52), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, input feature, MCI Check(94), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=192.168.1.8 (Vlan10), d=192.168.1.255, len 78, input feature, TCP Adjust MSS(96), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: tableid=0, s=192.168.1.8 (Vlan10), d=192.168.1.255 (Vlan10), routed via RIB
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109, len 40, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109, len 40, input feature, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109, len 40, input feature, MCI Check(94), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: tableid=0, s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109 (GigabitEthernet8), routed via RIB
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109 (GigabitEthernet8), len 40, output feature, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109 (GigabitEthernet8), len 40, output feature, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109 (GigabitEthernet8), len 40, rcvd 3
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109, len 40, stop process pak for forus packet
Mar 16 07:41:47 EDT: IP: s=185.175.93.105 (GigabitEthernet8), d=72.83.148.109, len 40, enqueue feature, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105, len 40, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, sending
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, output feature, Post-routing NAT Outside(24), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, output feature, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, output feature, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, output feature, NAT ALG proxy(59), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, output feature, Post-Ingress-NetFlow(74), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, output feature, Dialer idle reset(93), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 07:41:47 EDT: IP: s=72.83.148.109 (local), d=185.175.93.105 (Dialer1), len 40, encapsulation failed
add:
dialer-list 1 protocol ip permit
to your configuration...
also remove 'ip address dhcp' from the physical interface:
--> no ip address dhcp
no change after adding the dialer-list command
before removing 'ip address dhcp' from Gig8 there was an ip address assigned:
Dialer1                    unassigned      YES DHCP   up                    up
GigabitEthernet8           108.51.198.232  YES DHCP   up                    up
NVI0                       108.51.198.232  YES unset  up                    up
#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  108.51.198.1            0   3e61.040b.5ded  ARPA   GigabitEthernet8
Internet  108.51.198.232          -   1c6a.7ac6.9d91  ARPA   GigabitEthernet8
Internet  192.168.1.1             -   1c6a.7ac6.9d7e  ARPA   Vlan10
once removing the dhcp command from Gig8 the WAN IP goes away.  The Dialer1 int does not get any WAN IP:
#sh ip int brief
GigabitEthernet8           unassigned      YES unset  up                    up
NVI0                       unassigned      NO  unset  up                    up
debug still shows encapsulation failed:
Mar 16 09:53:09 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8, len 66, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8, len 66, input feature, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8, len 66, input feature, Virtual Fragment Reassembly(36), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8, len 66, input feature, Virtual Fragment Reassembly After IPSec Decryption(52), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8, len 66, input feature, MCI Check(94), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8, len 66, input feature, TCP Adjust MSS(96), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.1 (local), d=192.168.1.98, len 56, local feature, NAT(2), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.1 (local), d=192.168.1.98 (Vlan10), len 56, sending
Mar 16 09:53:09 EDT: IP: s=192.168.1.1 (local), d=192.168.1.98 (Vlan10), len 56, output feature, NAT Inside(8), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.1 (local), d=192.168.1.98 (Vlan10), len 56, output feature, Common Flow Table(27), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.1 (local), d=192.168.1.98 (Vlan10), len 56, output feature, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.55 (Vlan10), d=192.168.1.1, len 67, stop process pak for forus packet
Mar 16 09:53:09 EDT: IP: s=192.168.1.55 (Vlan10), d=192.168.1.1, len 67, enqueue feature, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.96 (Vlan10), d=66.172.17.41, len 76, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.96 (Vlan10), d=66.172.17.41, len 76, input feature, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:09 EDT: IP: s=192.168.1.96 (Vlan10), d=66.172.17.41, Stateful Inspection(28), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:10 EDT: IP: s=192.168.1.55 (Vlan10), d=192.168.1.1 (Vlan10), len 67, rcvd 3
Mar 16 09:53:10 EDT: IP: s=192.168.1.55 (Vlan10), d=192.168.1.1, len 67, stop process pak for forus packet
Mar 16 09:53:10 EDT: IP: s=192.168.1.55 (Vlan10), d=192.168.1.1, len 67, enqueue feature, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 09:53:11 EDT: IP: s=192.168.1.152 (Vlan10), d=162.247.242.19, len 52, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE (Dialer1), len 316, encapsulation failed
on the dialer interface, configure:
ip address negotiated
The entire config should look like this (important parts marked in bold):
import all
! class any
vpdn enable
vpdn-group 1
vpdn-group pppoe
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
pppoe enable
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
interface Async3
no ip address
encapsulation slip
interface Dialer1
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
all bold items and non-bold items match exactly just no ip address is received/given to the Dialer1 interface.
debug ip packet log still shows encapsulation failed.
Mar 16 13:42:48 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:48 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:48 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Virtual Fragment Reassembly(36), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:48 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Post-Ingress-NetFlow(74), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:48 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130 (Dialer1), len 496, output feature, Dialer idle reset(93), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:48 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130 (Dialer1), g=216.234.64.130, len 496, forward
Mar 16 13:42:48 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130 (Dialer1), len 496, encapsulation failed
Mar 16 13:42:48 EDT: IP: s=192.168.1.152 (Vlan10), d=192.168.1.1, len 61, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:49 EDT: IP: s=192.168.1.152 (Vlan10), d=192.168.1.255 (Vlan10), len 78, rcvd 3
Mar 16 13:42:49 EDT: IP: s=192.168.1.152 (Vlan10), d=192.168.1.255, len 78, stop process pak for forus packet
Mar 16 13:42:49 EDT: IP: s=192.168.1.152 (Vlan10), d=192.168.1.255, len 78, enqueue feature, TCP Adjust MSS(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:49 EDT: IP: tableid=0, s=192.168.1.152 (Vlan10), d=192.168.1.255 (Vlan10), routed via RIB
Mar 16 13:42:50 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:50 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:50 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Virtual Fragment Reassembly(36), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:50 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Virtual Fragment Reassembly After IPSec Decryption(52), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:50 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8 (Dialer1), g=8.8.8.8, len 66, forward
Mar 16 13:42:50 EDT: IP: s=192.168.1.98 (Vlan10), d=8.8.8.8 (Dialer1), len 66, encapsulation failed
Mar 16 13:42:52 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Common Flow Table(5), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:52 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Stateful Inspection(7), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:52 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Virtual Fragment Reassembly(36), rtype 0, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:52 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130, len 496, input feature, Post-Ingress-NetFlow(74), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:52 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130 (Dialer1), len 496, output feature, Dialer idle reset(93), rtype 1, forus FALSE, sendself FALSE, mtu 0, fwdchk FALSE
Mar 16 13:42:52 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130 (Dialer1), g=216.234.64.130, len 496, forward
Mar 16 13:42:52 EDT: IP: s=192.168.1.59 (Vlan10), d=216.234.64.130 (Dialer1), len 496, encapsulation failed
maybe this configuration is not supported by service-provider, Verizon for FiOS service?
save the configuration (wr mem), then reboot the router. Also, post the running configuration just to check if everything is correct...
try to make the changes marked in bold:
import all
! class any
vpdn enable
vpdn-group 1
vpdn-group pppoe
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
duplex auto
speed auto
pppoe enable
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
--> no ip tcp adjust-mss 1452
interface Async3
no ip address
encapsulation slip
interface Dialer1
--> ip mtu 1460
no ip redirects
no ip unreachables
no ip proxy-arp
--> ip tcp adjust-mss 1420
ip flow ingress
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
made changes and reloaded but still no ip on the Dialer1 interface.  debug still shows encapsulation failed on Dialer1 int.
below is config:
interface BRI0
 no ip address
 encapsulation hdlc
 shutdown
 no ip address
 shutdown
 duplex auto
 speed auto
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 duplex auto
 speed auto
 pppoe enable group global
interface Vlan1
 no ip address
 shutdown
interface Vlan10
 ip nat inside
interface Async3
 no ip address
 encapsulation slip
interface Dialer1
 no ip redirects
 no ip unreachables
 no ip proxy-arp
 ip mtu 1460
 ip flow ingress
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 no cdp enable
no ip http server
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
ip address dhcp
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan10
ip nat inside
interface Async3
no ip address
encapsulation slip
no ip http server
