C921 ISR WLAN Compatibility
bepstein111
Hi Community-
I've inherited a bunch of "old" gear from my workplace, and trying to figure out how I can use any of it. I successfully setup a C921 ISR as a router, however despite a lot of research, I can't seem to find any definitive answer as to whether or not I can use this router to configure an Aironet AP I also have.
Thanks in advance!!
Jens Albrecht
Hello @bepstein111,
the router and the AP are 2 totally different and independent devices.
Most APs can run in 2 different modes.
One is the autonomous mode so that the AP runs as a stand-alone device meaning that you connect to the AP via console cable and configure it using the CLI.
The second mode is the light-weight mode where the AP is controlled by a WLC - a wireless lan controller. In that case the configuration of the AP is done on the WLC.
However, a c921 router cannot be used as a WLC which typically is a separte device.
https://www.cisco.com/c/en/us/products/collateral/routers/900-series-integrated-services-routers-isr/q-and-a-c67-741630.html
Check this' I think you need to order ISR LTE
Note:- ISR LTE is wireless router it can work with AP as bridge but can not config AP via it.
MHM
Jens Albrecht
Hello @bepstein111,
