cable modem to cisco router
megacafenui
to avoid double natting.
would it work if my cisco router interface have this configuration
int f0/0 DHCP
no nat outside
int f0/1 192.168.215.1
no nat inside.
basicially i am grabbing dhcp from the modem and having it do NAT
then I turn nat off on cisco router.
that is definitely going to work and quite a common setup. Just make sure to set the default route on the Cisco to the actual IP address assigned to your cable modem, as I have seen multiple cases where:
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
or
ip route 0.0.0.0 0.0.0.0 dhcp
doesn't seem to work well.
or
thanks for responding.
another question if I reverse it. would it work as well? example
cable modem disable nat
and leave nat on cisco router
int 0/0
nat outside
int f0/1
nat inside
for that to work you would have to put your cable modem in bridge mode. Other than that, yes that would work.
appreciated thanks you much...
