05-20-2011 10:36 AM - edited 03-04-2019 12:28 PM
We're having a duscussion here and the bet is the same cable - straight-thru ethernet - is used for a serial card be it single, dual or quad port - is that true?
05-20-2011 11:49 AM
Not true. T1 / E1 cable has his own pinout, pairing, and impedance characteristics, different from ethernet.
That is easily revelaled with an Internet search.
05-20-2011 12:04 PM
Maybe I should have worded that differantly - knowing T1 uses 1245 while etherenet user 123
6 - a straight thru patch cable can be used ?
05-20-2011 12:28 PM
As above - cables are different, each application uses his own.
Then if you want to do things the wrong way - up to you and good luck.
05-20-2011 12:37 PM
Ok - to connect them back-2-back a t1 crossover is used where pins 12 7 45 are crossed. But if we are connecting to a serial rj45 card what type of cable is used and can a straight-thru ethernet cable be used?
05-20-2011 12:49 PM
Again - for the third time - a straight T1 cable. Not an Ethernet cable.
05-20-2011 01:06 PM
Not looking to be difficult but - the straight thru ethernet will
work - right, your point is have a proper cable made ?
05-20-2011 02:13 PM
I will reiterate Paolos comments. You save nothing and induce a little doubt by jury rigging. just put the right cable in.
Don't mess with Layer 1.
05-20-2011 03:31 PM
Understood - thanks fealls -
