Camera without a gateway
dbronco
We recently received a camera for testing purposes that is very basic in nature. It was designed for a very limited and specific use case but I'm trying to figure out if I can expand this. In the camera setup, there is only an option to set an IP address - no mask or gateway. And, it requires a dedicated video client. The client and camera need to be on the same subnet since the camera doesn't have a gateway. It works on a single site where I have both camera and client on the same VLAN.
What I'd like to do, or at least explore, is be able to view this camera from some of my other sites as well and I haven't been able to figure this out yet. Without a configurable gateway, is this possible? I
I have Catalyst 9300s as my routers at most of my sites, with a few 3850s that are scheduled to be replaced.
Only run ip arp proxy under vlan SVI of camera'
This make camera can connect to any IP outside it subnet without config GW
MHM
MHM
dbronco
I just found this based on your comment https://www.cisco.com/c/en/us/support/docs/ip/dynamic-address-allocation-resolution/13718-5.html#:~:text=Proxy%20ARP%20is%20the%20technique,to%20the%20%22real%22%20destination
I think I understand what you're saying. So, if the camera is on VLAN 66 then I would run
conf t
interface vlan 66
no ip proxy-arp
interface vlan 66
 ip proxy-arp <<- you need proxy not disable it since camera not have GW
MHM
dbronco
Thank you for the clarification. I was able to get this to work in my lab. I'm still having some problems with certain computers being able to access the camera but I'll keep working on that. I'll be trying this in my production environment today.
