ISP load balancing on ASA 5525 using ECMP (Equal-Cost Multi-Path)
gilbertabotchi
Hi everyone hope you all doing. I'm winsherter a network administrator with less than a year experience. I'm having issue at work with this topology ::
I should Implement ISPs load balancing on the ASA 5525 using ECMP (Equal-Cost Multi-Path Routing)
After nights of researching and labing in EVE, I can't get ECMP working...Maybe I'm going the wrong way. NEED HELP!
some ASA support ECMP
https://www.cisco.com/c/en/us/support/docs/security/adaptive-security-appliance-asa-software/115986-asa-eqm-products-configuration-example.html
some ASA dont support ECMP
sorry you need to run PBR make some internal subnet use ISP2 and default route toward ISP1 for all other internal subnet
MHM
MHM
