04-24-2008 12:12 AM - edited 03-03-2019 09:41 PM
I have a Cisco 877 at home with a nework hardrive attached to one of the 4 ethernet ports.
My laptop has the Cisco VPN Client that I use with my Cisco ASA 7 Concentrator and I thought it would be great to be able to use this to connect to my home network in this way. Can the Cisco 877 be configured in this way? I don't have radius so local authentication is only the way.
Thanks in advance
04-24-2008 02:05 AM
The datasheet for the 870 series indicates that this model does indeed support IPSEC VPN tunnels - http://www.cisco.com/en/US/prod/collateral/routers/ps380/ps6200/product_data_sheet0900aecd8028a976_ps380_Products_Data_Sheet.html
04-24-2008 02:25 AM
Great, would you know how I can configure the 877 to accept a VPN connection from my Cisco VPN Client?
04-25-2008 10:54 AM
Cisco SDM has a GUI wizard you can use.
