Can anyone share a configuration file of ISR C1121-8PLTEP config?
hellothisisvic
Can anyone share a configuration file of ISR C1121-8PLTEP workable config? Just need a VLAN on Gi0/1/1 and Gi0/1/3. Then DHCP pool on that vlan. To achieve if a terminal device(PC) connect to Gi0/1/1 or Gi0/1/3, it can get a DHCP ip address. I tried to config the Gi interface with ip address. Seems like this device not accept that. And the DHCP seems like not working as the Windows PC didn't get any ip from the Gi interface.
Thank you so much for helping
umeshpathak
Considering your request for DHCP i am writing my point of view.
Just configure vlan,SVI ,configure the IP address on that SVI  ,remove the IP from loopback or delete loopback.So the device on vlan 100 can request IP from the router(DHCP SERVER).
vlan 100
Int vl100
ip add 192.168.0.1 255.255.255.0
ip nat inside
no shut
do you have a cellular or Ethernet connection at the WAN side ? Below is a sample config for connecting to Ethernet on the WAN side (important parts marked in bold). If that does not resemble what you have, post your current running configuration (sh run):
platform qfp utilization monitor load 80
no platform punt-keepalive disable-kernel-core
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
subscriber templating
crypto pki certificate chain TP-self-signed-4175586959
diagnostic bootup level minimal
redundancy
mode none
controller Cellular 0/2/0
lte modem link-recovery disable
vlan internal allocation policy ascending
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8
interface GigabitEthernet0/0/0
ip address dhcp
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/1/0
interface GigabitEthernet0/1/1
interface GigabitEthernet0/1/2
interface GigabitEthernet0/1/3
interface GigabitEthernet0/1/4
interface GigabitEthernet0/1/5
interface GigabitEthernet0/1/6
interface GigabitEthernet0/1/7
interface Cellular0/2/0
ip address negotiated
ipv6 enable
interface Cellular0/2/1
no ip address
shutdown
interface Vlan1
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0 dhcp
access-list 1 permit 192.168.1.0 0.0.0.255
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
control-plane
line con 0
transport input none
stopbits 1
line vty 0 4
login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
end
hellothisisvic
Hi Georg,
Thank you so much for the reply. I have a Cellular 0/2/0 connected on the ISP side but not using the Gi0/0/0. All local flow comes from Gi0/1/1 and Gi0/1/3 in Vlan 100, then goes to the 4G ISP through Cellular 0/2/0.  Here is the config
version 17.3
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.0.1
ip dhcp pool testlocal
network 192.168.0.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.0.1
interface Loopback0
ip address 192.168.0.1 255.255.255.0
no ip address
shutdown
negotiation auto
no ip address
shutdown
negotiation auto
switchport access vlan 100
ip nat outside
dialer in-band
dialer-group 1
ipv6 enable
pulse-time 1
no ip address
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan100
description testlocal
ip address dhcp
ip nat inside
ip http server
ip nat inside source list 1 interface Cellular0/2/0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0/2/0
dialer-list 1 protocol ip list 1
umeshpathak
vlan 100
Int vl100
ip nat inside
no shut
