Can anyone tell me why I can't copy images above 8MB?
ehyman
When I attempt to tftp an IOS image larger than 8MB, I get a message stating I don't have enough space. The flash was recently upgraded from 8MB to 32MB and the router has 128MB of DRAM (See attached show version).
Router#dir
Directory of flash:/
No files in directory
33030140 bytes total (33030140 bytes free)
Router#
The following is the 12MB image I'm trying to copy.  I have tried to copy multiple images over 8MB with no success.
09/06/2013  04:58 PM        12,373,380 c3640-i-mz.124-25d.bin
Here's the error.
Router#copy tftp flash
Address or name of remote host [10.1.1.6]?
Source filename [c3640-i-mz.124-25d.bin]?
Destination filename [c3640-i-mz.124-25d.bin]?
Accessing tftp://10.1.1.6/c3640-i-mz.124-25d.bin...
Erase flash: before copying? [confirm]
Erasing the flash filesystem will remove all files! Continue? [confirm]
Erasing device...
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
eeeeee ...erased
Erase of flash: complete
Loading c3640-i-mz.124-25d.bin from 10.1.1.6 (via FastEthernet0/0):
%Error copying flash:/c3640-i-mz.124-25d.bin (No space left on device)
Router#
10 Replies 10
cadet alain
Router uptime is 7 minutes
System image file is "flash:c3640-io3-mz.122-26c.bin"
So you've got an IOS in flash but dir  doesn't show it,that's strange ! Does show flash: is also empty ?
Alain
The flash was empty at the time I was creating this post.  I was in the middle of troubleshooting.
Router#sh flash
System flash directory:
File  Length   Name/status
  1   6934228  c3640-io3-mz.122-26c.bin
[6934292 bytes used, 26095848 available, 33030140 total]
32768K bytes of processor board System flash (Read/Write)
Router#
Try using TFTPd32 or TFTPd64.
I have been using TFTP32.
Post the output to the command "dir".
Router#dir
    1  -rw-     6934228                      c3640-io3-mz.122-26c.bin
33030140 bytes total (26095848 bytes free)
Router#
did you try to format flash from console of device ?
There is no format command available.
I tried the instruction in the link but it still copies 8MB of the file and then stops with the same error.
