Can crypto just break like tat although configuration is correct?
ahpark78
Would like to check will crypto VPN just broken like tat although config is correct? I have a traffic which cannot be encrypted..the VPN module is fine..
TIA
kamal-learn
Level 4
Level 4
HI
please elaborate more !! i.e if your usiong nat it will break if you re using AH, so you can go with ESP for nat but if you use PAT it will break also since its header is portless, so you can use TCP or UDP in conjuction with ESP for whaever NAT, PAT and you ll be good to go without breaking.
the same RRI will help in the case of netwoth extention MODE.
do further researchs on all that stuff.
Pls do rate the poste if it does help
