leased line backup problem
senthil.gabriel
Plz help me out leased line backup problem-
i configuerd ISDN for Leased line backup but after Leased line goes down Traffic is not routed thro ISDN line .when i put this -
ip nat inside source list 101 interface bri0 overload
Then traffic is routed through ISDN but after this leased line is not working so plzz tell my right configrutation for this iam sending the configrutation with the attachment
16 Replies 16
sourabhagarwal
Level 4
Level 4
I feel you can test after doing these changes. It'll cause some downtime, so you can schedule changes in off business hours or whenever you feel is the right time.
interface Loopback0
ip nat outside
interface BRI0
no ip nat outside
interface Serial0
no ip nat outside
see if it works .... rate if it does ...
jitesh1982
hi senthil as you have described that after hardening command
ip nat inside source list 101 inteface bri0 overload it works .but when lease line come up it doesnt
it happens because u cant nat 1 access list to multiple interface .
so u can do 1 thing prepare 1 more access list .config will be like this
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 102 permit ip 192.168.5.0 0.0.0.255 any
ip nat inside source list 101 interface Loopback0 overload (either loopback0 or serial0)
ip nat inside source list 102 interface bti0 overload
just try this and this will work
try putting a metric instead of backup interface also. I have found that this works in some of the cases.
regards
Ashish Gupta
I agree Jithesh and rated too ;)
thanx jitesh today i fixed a downtime with my client i will check this configruation
but my dought is if i do this then nating will happen throug loopback or bri0 ?
senthil.gabriel
can u discribe me? how it will work plzzz
plzz find out the configruation with attachment
my problem is after leased line gose down ISDN is comming up and traffic is going from router to outside via bri but from pc traffic is not going outside
from i am able to ping bri but iam not able to ping isp gateway may be there is some issue of nating plzz any body can help for the same
Hi Senthil
I did face similar kinda probs in the past in giving BRI as a backup for the customer who has availed Internet services..
I would rather suggest to check out with the SP if they can provide/map the same WAN ip to your backup/isdn.
This can be achieved by configuring the radius attributes accordingly for the isdn bri backup id.
Also you can avail a /30 ip from your SP and have it configured as a loopback and do the overload over the loopback interface.
As per your requirement this will provide 2 gateways to you with redundancy built in.
Did you configure the loopback with a public ip and checked out the same with the necessary config ?
did you check for the nat translation while your main link is down ?
regds
Note: Attachment missing in your earlier post.
From your post, its clear that with BRI0 overload it works , But with lo0 overload it doesnt work during backup.
Can u pls check with your ISP wheter a higher metric route for the loopback is pointed via the BRI interface so that loopback reachability is fine during LL failure.
Hope this helps
regards
vanesh k
ya i configured the loobback with public ip
plzz check the configuration iam sending you with the attachment
in the configuration
check this statment
ip nat inside source lits 101 interface loopback overload
after leased line goes down if i ping from router to any public ip iam getting reply
but if i ping frm my pc iam not getting reply
but if put statment like this
ip nat inside source lits 101 interface bri0 overload
after this iam able to ping public ip from my pc also
ping works fine after ur LL failure bcos it takes the BRI ip as source and works fine .But ur Lan ips gets natted to loopback , so pls check whether reverse route for Loopback via your backup interface is present or not at ISP end.
regards
vanesh k
i have two wan link one is leased line second is ISDN line both are for airtel
you mean to say i need to check with our ISDN side ?
As you said while on ISDN , pat is not working , so suspecting some routing issue in backup from ISP side . So just check how is the routing done at ISP end . Primary route for Loopback via LL and secondry route via ISDN . Pls check once to isolate the routing problem at ISP end.
regards
vanesh k
1.Are you manualling shutting down the serial interface using shut command to check the backup ?
2.Do switch off the modem to make the link down and check the backup connectivity.
3.Did you check up whether your isdn comes up when your primary link goes down ?
4.you can verify the same using Show isdn active/show isdn status once your primary link is down.
5.Also you need to go through the steps already mentioned by Vanesh in his earlier post.
regds
