Can NBAR filter traffic in one-interface routing?
mmedwid
Level 3
Level 3
Say I have a routers A and B and a host C. Router A has inside FE 192.168.1.1, Router B has inside interface 192.168.1.2 and host C has FE interface 192.168.1.3.
Router A has a route "ip route 192.168.2.0 255.255.255.0 192.168.1.2". If host C sent an NBAR probhited packet say to host 192.168.2.3 - would Router A be able to filter that traffic via NBAR?
Of course it would assume ICMP redirects were not in play. Thank-you.
Collin Clark
NBAR stands for Network-Based Application Recognition. It does not restrict or filter by itself, it just 'discovers' the applications as they traverse the router. You can use ACL's to filter unwanted traffic.
Hope that helps.
Yes - NBAR is used in conjunction with ACLs to do the filtering. So say you put said ACL at the inside interface - would the traffic in my scenario be filtered?
An ACL can be used to filter applications. AFAIK ACL's can't be tied to NBAR for filtering. If you know of a way, please post a config or link. Thanks.
