Can one create a router-on-a-stick configuration without using vlans?
MicJameson1
Hi.
Instead of a
vlans with a router-on-a-stick
configuration, can one achieve the same connectivity result without vlans-- can one simply create on a
router port: sub-interfaces with ip-addresses in each subnet, and thus allow inter-subnet connectivity?
If not, why not?
Thank you.
Joseph W. Doherty
The problem you would have is the subinterfaces normally have some way to identify "their" traffic, such as a
VLAN tag, frame-relay DLCI, ATM PVC, etc.
You could, though, have different interfaces connect to the same L2 domain, each supporting a different network.
You could also have multiple networks on a single interface using secondary addressing but there are "issues" with the latter.
6 Replies 6
balaji.bandi
How will they have communication if you do not have
vlan
tagging, how you identified where the packet from and where this need to go.
Other method you can do VRF ? (that totally different over engineering to solve simple solution).
BB
Thanks for the reply.
My thinking is that workstation GREEN from 10.0.1.0/24 connects to an L2 switch that connects to a router. Workstation RED from 10.0.2.0/24 connects to same switch. When each communication traverses from the switch to the router, because each
router sub-interface
is in a different subnet, it works.
Where is my understanding incorrect?
Thanks.
SW-R
Use one link for each
vlan
Here you dont need
subinterface
config in R
GREEN is Different broadcas domain and RED is different BROACAST domain in Layer 2 point of view.
To bridge between the Layer 2 domain, you need Router to route the the traffic in appropriate way.
 better explanation :  (dont want to invent wheel again)
https://www.ciscopress.com/articles/article.asp?p=2990405&seqNum=2
BB
This is not production question, this is theoretical question.
It's different L2 broadcast domain only if there are
vlans
. It is same L2 broadcast domain if there are no
vlans.
so as asked...
Workstation GREEN from 10.0.1.0/24 connects to an L2 switch that connects to a router. Workstation RED from 10.0.2.0/24 connects to same switch. When each communication traverses from the switch to the router, because each
Joseph W. Doherty
