Can only ping using Extended Ping feature
garybeach
I am trying to set up some of our ADSL Routers with GRE Tunnels but some will not work. On the routers that do not work, the normal ping will does not work to start with. I can ping using the extended ping feature, but a straight forward ping does not.
Other routers where the ping works, the GRE Tunnel works straight away.
Anybody got any ideas?
17 Replies 17
Thanks for all your help guys.
Turns out the Telco ahd mis-configured these sites with different loopback addresses to the ones that we had given to them.
As soon as they had changed their configs, the 4 sites worked perfectly.
Many Thanks again
Gary
Gary
Thanks for letting us know that the problem is resolved and how it was resolved. And thanks for using the rating system to indicate that the problem is resolved. It makes the forum more useful when people can read about a problem and know that they will read the solution to the problem.
I encourage you to continue your participation in the forum.
Rick
Rick
Hi Gary,
I am very glade that we had succeeded helping you out of this, thanks for rating all who helped you, and please always try coming back when facing any problems.
BR,
Mohammed Mahmoud.
