Can ping but cannot telnet.. - URGENT
winanjaya
Dear All,
I am very new with this, I had a WAN connection between 2 branches(A & B)
A is on 172.16.1.0
A has mail server on 192.168.1.9 (dmz)
B is on 172.16.2.0
B has also mail server on 172.16.2.6
I can ping from any PC of network A (ie. 172.16.1.88) to the mail server of branch B (172.16.2.6)
I can also telnet from any PC from network A (ie. 172.16.1.88) to mail server of branch B (ie. telnet 172.16.2.6 25)
The problem is on the mail server of branch A (192.168.1.9 dmz) ..
it can ping to mail server on branch B but it cannot telnet into it.. what happen? ..please advise ..
thanks a lot in advance
Winanjaya
12 Replies 12
zaeemarshad
Is port 23 open on that machine? Either it is firewalled or the telnet daemon is not running on it. Check for these.
Zaeem
Telnet service is already opened in that machine, and it's not firewalled because I (on 172.16.1.88) can telnet to that machine.. the problem is that I cannot telnet to that machine( 172.16.2.6) from my mailserver (192.168.1.9) .. please advise what should I do? .. thanks a lot in advance
Winanjaya
Sounds like an access-control-list problem on the B side or the A side, or both.
Are there any ACLs being applied along the traffic path which have "permit icmp any any"? That would explain why everybody can ping everybody. Is it then followed by more explicit permit or deny commands that allow the network at A (172.16.1.0) to telnet to the mailserver at B on TCP port 25, but don't allow for the A-side DMZ 192.168.1.0 network or hosts to do the same?
If there are no explicit commands to permit from the A-side DMZ, then it's possible that the implicit "deny all" at the end of each ACL could also be preventing the mailserver in the A-side DMZ from telnetting to TCP port 25 on the B-side.
Thanks but there is no access list in both side ..then what should I do? . please advise
Winanjaya
can u paste your config ......
Below are my routers config for your review..
Config for location B CISCO 2610 (172.16.2.0/24):
Ro_jkt>en
Password:
Ro_jkt#sh run
Building configuration...
Current configuration : 1898 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Ro_jkt
ip subnet-zero
ip name-server 172.16.1.3
interface FastEthernet0/0
ip address 172.16.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
ip address 172.16.254.30 255.255.255.252
frame-relay interface-dlci 132
router eigrp 100
network 172.16.0.0
no auto-summary
eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.254.29
ip http server
ip pim bidir-enable
call rsvp-sync
voice-port 1/0/0
cptone ID
timeouts wait-release 1
voice-port 1/0/1
cptone ID
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern +20
port 1/0/0
dial-peer voice 2 pots
port 1/0/1
dial-peer voice 9 voip
destination-pattern +11
session target ipv4:172.16.254.29
ip qos dscp cs5 media
dial-peer voice 10 voip
destination-pattern +21
session target ipv4:172.16.254.14
dial-peer voice 11 voip
destination-pattern +22
session target ipv4:172.16.254.26
dial-peer voice 12 voip
destination-pattern +23
session target ipv4:172.16.254.6
dial-peer voice 13 voip
destination-pattern +24
session target ipv4:172.16.254.10
dial-peer voice 14 voip
destination-pattern +25
session target ipv4:172.16.254.18
dial-peer voice 15 voip
destination-pattern +26
session target ipv4:172.16.254.22
end
Ro_jkt#
Config for location A CISCO 3640 (172.16.1.0/24)
Ro_kwc>en
Password:
Ro_kwc#sh run
Current configuration : 4435 bytes
version 12.2
service timestamps debug datetime localtime
service timestamps log datetime localtime
service password-encryption
hostname Ro_kwc
logging buffered 4096 debugging
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
clock timezone WIB 7
ip subnet-zero
ip address-pool local
chat-script mod ABORT ERROR ABORT BUSY "" "AT" OK "ATDT \T" TIMEOUT 30 CONNECT \
c
chat-script offhook "" "ATH1" OK \c
ip address 198.168.0.1 255.255.240.0 secondary
ip address 172.16.1.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
no fair-queue
interface Serial0/0.2 point-to-point
description PVC to Ro_jkt
ip address 172.16.254.29 255.255.255.252
interface Serial0/1
no ip address
shutdown
clockrate 2000000
interface Group-Async1
ip unnumbered FastEthernet0/0
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer enable-timeout 6
async mode interactive
peer ip address forced
peer default ip address pool default
ppp callback accept
ppp authentication pap
ppp ipcp accept-address
group-range 33 40
router eigrp 100
network 172.16.0.0
network 198.168.0.0 0.0.15.255
no auto-summary
ip local pool default 172.16.1.241 172.16.1.254
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.5
ip http server
ip pim bidir-enable
logging trap debugging
call rsvp-sync
end
Ro_kwc#
Hopefully with this simple network diagram below, can help you to determine what's my problem..
Users ' All users can telnet to 172.16.2.6 25
Switch
Router 3640 (172.16.1.2)
|----------- Mailserver in DMZ 192.168.1.9 the problem goes here (I can ping to 172.16.2.6 but cannot telnet to 172.16.2.6 25)
PIX (172.16.1.1)
Location B: 172.16.2.0/24
Router 2610 (172.16.2.1)
|---------- DNS & Gateway 172.16.2.3
|---------- Mailserver 172.16.2.6
Switch
Users
please help .. what should I do?? ..
Winanjaya
Since Mail Server ( 192.168.1.9 ) in Branch A can ping to Mail Server ( 172.16.2.6 ) in Branch B there should'nt be a problem with routing.
You mentioned that your Mail Server ( 192.168.1.9 ) in Branch A is in DMZ that means it's behind a firewall. Check your firewall if port 25 is open for Mail Server (192.168.1.9) in Branch A to reach/receive any network/ip or segment 172.16.2.0/24 or just the host 172.16.2.6/32
If your Firewall is PIX, check for drop packet when you try to telnet port 25 from Mail Server ( 192.168.1.9 ) in Branch A to Mail Server ( 172.16.2.6 ) in Branch B. Concentrate on the Firewall.
I had "access-list dmz permit ip any any" .. so it must allowed for any service .. am I correct? .. but it still not working? .. ..why .. please advise ..
name 172.16.0.0 inside_net
name 172.16.1.0 server_net
name 202.x.y.z outside_net
name 192.168.1.0 dmz
access-list inbound_filter permit tcp any host 202.x.y.smtp eq smtp
access-list inbound_filter permit icmp any any
access-list inbound_filter permit tcp any host 202.x.y.pop3 eq pop3
access-list inbound_filter permit icmp any host 202.x.y.z
access-list inbound_filter permit tcp any host 202.x.y.ftp eq ftp
access-list inbound_filter permit tcp any host 202.x.y.ftp eq ftp-data
access-list inbound_filter permit tcp any host 202.x.y.www eq www
access-list nonat permit ip inside_net 255.255.0.0 dmz 255.255.255.0
Winanjaya,
I'm missing in "access-list inbound_filter" that you permit telnet traffic, were ICMP traffic is allowed. Maybe this is the problem ?
regards,
RdR
Hi, I'm not a PIX FW Expert but in my experience you should have this at minimum;
Example (cause I don't know your ACL Group and IPs):
DMZ Interface ACL Group >> inside_filter
OUTSIDE Interface ACL Group >> outside_filter
DMZ MAIL Server IP >> 192.168.1.9
DMZ MAIL Server NAT IP >> 202.1.2.3
OUTSIDE MAIL Server IP >> 172.16.2.6
1. DMZ MAIL Server to OUTSIDE MAIL Server
access-list inside_filter permit tcp host 192.168.1.9 host 172.16.2.6 eq 25
2. OUTSIDE MAIL Server to DMZ MAIL Server
access-list outside_filter permit tcp host 172.16.2.6 host 202.1.2.3 eq 25
Troubleshooting:
Cisco has done a good job on their PIX FW logging. From the logs you can tell which port and which host has been denied by looking at the packet drop during the time you are trying to telnet via port 25 (it will tell you the source, destintion, port, and the interface acl group). I usually enable logging through console so I can see the error real time.
medan has pointed out the problem correctly u've not specified the inside_filter and outside_filter stuff
