Can ping from Router, but not from Client PC
ddevecka
I configure routers about once or twice a year, so I am a noob.
I just set up a basic config on a 2600 series router, but I can't get to the internet through the router. From the router I can ping 4.2.2.2 and next hop, but from client PC I can inside and outside interfaces but not next hop router or 4.2.2.2. Here is a copy of my config.
Thanks for any pointers.
version 12.3
hostname Router-Loaner
boot-start-marker
boot-end-marker
enable secret 5 ******
enable password ******
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 172.18.0.1 172.18.127.255
ip dhcp pool NET-POOL
   network 172.18.0.0 255.255.0.0
   default-router 172.18.0.1
   dns-server 1.8.13.144 1.8.15.10
   lease 10
ip audit po max-events 100
interface FastEthernet0/0
 ip address 1.18.54.2 255.255.255.192
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 172.18.0.1 255.255.0.0
 duplex auto
 speed auto
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 1.18.54.1
snmp-server community public RO
line con 0
line aux 0
line vty 0 4
 password ******
 login
end
12 Replies 12
hbackus
Do you have an access list to permit traffic.
ip access-list extended acl-Internet-In
permit icmp any host 1.18.54.2 echo-reply
 permit icmp any host 1.18.54.2 unreachable
 permit icmp any host 1.18.54.2 source-quench
 permit icmp any host 1.18.54.2 redirect
 permit icmp any host 1.18.54.2 time-exceeded
 permit icmp any host 1.18.54.2 parameter-problem
 permit icmp any host 1.18.54.2 timestamp-request
 permit icmp any host 1.18.54.2 timestamp-reply
 permit icmp any host 1.18.54.2 information-request
 permit icmp any host 1.18.54.2 information-reply
 ip access-group acl-Internet-in in
 duplex auto
 speed auto
Marvin Rhoads
No access-list is necessary since there is no security setup on this router (by the way it's wide open to all sorts of hacking in many ways).
As to why your hoist cannot reach the internet while the router can, you don't have any NAT setup. Without it, your host's private IP address will pass unchanged via the router and your provider will not route private IP address ranges.
The configuration details vary according to whether you want to simply allow outbound (inside-initiated) or inbound traffic.
RDGamm
I have the same issue.  I can reply with captured CLI info.
show run
Building configuration...
Current configuration : 2596 bytes
! Last configuration change at 15:34:43 Central Tue Aug 29 2017
version 15.4
service password-encryption
hostname DNCEF
boot-start-marker
boot-end-marker
enable secret 5 ############################
no aaa new-model
clock summer-time Central recurring last Sun Mar 1:00 last Sun Oct 2:00
ip dhcp excluded-address 192.168.30.254
ip dhcp pool INTERNET
 network 192.168.30.0 255.255.255.0
 default-router 192.168.30.254
 dns-server 192.168.20.187 192.168.20.254 8.8.8.8
 netbios-name-server 192.168.30.254
 domain-name 192.168.30.254
 lease 0 2
ip name-server 195.202.128.2
ip name-server 195.202.128.3
ip name-server 192.168.20.254
ip cef
login on-success log every 12
no ipv6 cef
cts logging verbose
license udi pid CISCO1921/K9 sn
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 interface GigabitEthernet0/0
 ip address 192.168.30.254 255.255.255.0
 ip nat inside
 ip nat enable
 ip virtual-reassembly in
 duplex auto
 speed auto
interface GigabitEthernet0/0.21
 ip nat inside
interface GigabitEthernet0/1
 ip address 10.1.1.1 255.255.255.0
 ip nat inside
 duplex auto
 speed auto
interface GigabitEthernet0/1/0
 ip address 192.168.20.187 255.255.255.0
 ip nat outside
 ip nat enable
 duplex auto
 speed auto
ip default-gateway 192.168.20.254
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 3 interface GigabitEthernet0/1/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.20.254
access-list 3 permit 192.168.0.0 0.0.0.255
access-list 3 remark CCP_ACL Category=2
control-plane
banner motd ^C
Unauthorized is prohibited.  You must contact the administrator for more
details.  Please disconnect and call the local administrator.
______________________________________________________________
^C
line con 0
 exec-timeout 20 30
 password 7 ###############
 logging synchronous
 login
line aux 0
line 2
 exec-timeout 20 30
 logging synchronous
 login
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 20 30
 password 7 #################
 logging synchronous
 login
 transport input none
scheduler allocate 20000 1000
end
DNCEF#show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       a - application route
       + - replicated route, % - next hop override
Gateway of last resort is 192.168.20.254 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.20.254
      192.168.20.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.20.0/24 is directly connected, GigabitEthernet0/1/0
L        192.168.20.187/32 is directly connected, GigabitEthernet0/1/0
      192.168.30.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.30.0/24 is directly connected, GigabitEthernet0/0
L        192.168.30.254/32 is directly connected, GigabitEthernet0/0
DNCEF#show ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.1.1.1                -   885a.9264.74a1  ARPA   GigabitEthernet0/1
Internet  192.168.20.96          57   0024.508e.10c0  ARPA   GigabitEthernet0/1/0
Internet  192.168.20.187          -   885a.9264.74b0  ARPA   GigabitEthernet0/1/0
Internet  192.168.20.254          0   c8d7.1924.3417  ARPA   GigabitEthernet0/1/0
Internet  192.168.30.1            0   34e6.d70c.f059  ARPA   GigabitEthernet0/0
Internet  192.168.30.254          -   885a.9264.74a0  ARPA   GigabitEthernet0/0
DNCEF#ping www.yahoo.com
Translating "www.yahoo.com"...domain server (192.168.20.254) [OK]
Sending 5, 100-byte ICMP Echos to 98.139.180.149, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 40/43/48 ms
DNCEF#ping 192.168.30.1
Sending 5, 100-byte ICMP Echos to 192.168.30.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
DNCEF#
Hello RDGamm
You have both domain and domain-less nat enabled however that shouldn’t cause nat to fail, it will just nat on the defined nat statement you specify. However your access-list encompass the outside interface ip range so try amending that.
no access-list 3
access-list 3 permit 192.168.30.0 0.0.0.255
access-list 3 permit 10.1.1.0.0 0.0.0.255
res
Paul
Kind Regards
Paul
Thanks! That seems to have it up and working.
try the configuration below (changes and additions are marked in bold):
version 15.4
hostname DNCEF
boot-start-marker
boot-end-marker
no aaa new-model
lease 0 2
ip cef
no ipv6 cef
cts logging verbose
redundancy
no ip address
shutdown
ip nat inside
no ip nat enable
duplex auto
speed auto
ip nat inside
ip nat inside
duplex auto
speed auto
ip nat outside
no ip nat enable
duplex auto
speed auto
no ip default-gateway 192.168.20.254
no ip http server
ip nat inside source list 100 interface GigabitEthernet0/1/0 overload
access-list 100 permit ip 10.1.1.0 0.0.0.255 any
access-list 100 permit ip 192.168.20.0 0.0.0.255 any
access-list 100 permit ip 192.168.30.0 0.0.0.255 any
control-plane
banner motd ^C
Thanks, very helpful!
Hello
@georg
access-list 100 permit ip 192.168.20.0 0.0.0.255 any <----- this isnt required as it the wan interface subnet
res
Paul
Kind Regards
Paul
My WAN interface is Gi0/1/0, so it does matter in this case.  I may use the .20 network in a subinterface scenario.
R
you have the same problem...can you post the configuration of your router ? In the initial post, there is a mixup of NVI NAT and traditional NAT, do you also have 'nat enable' and 'ip nat inside' configured on your interfaces ?
The interfaces I'm using are Gi0/0 and Gi0/1/0 and I have NAT enabled on both.  From the router I can ping the Internet (www.yahoo.com) and I can ping my machine at 192.168.30.1.  The machine at 192.168.30.1 can ping the router at 192.168.20.187 but cannot get to the Internet.
