COS to WAN ISP
Bob Greer
Level 4
Level 4
Hi there,
Thanks for reading.
My ISP is dropping packets from our BE COS queue.  I just found out we're not marking properly and only 10% of our traffic is in the correct COS queue.  Based on legacy requests, the ISP has COS2 set as highest priority.  The interface is the termination for IPSEC tunnels.  I need to mark those outgoing packets on those tunnels for COS2.  I think i need a map and a policy and then attach that policy to tunnel interfaces?
Thanks!
Bob
Hi Bob,
OK, only a slight tweak required for IOS-XE:
ip access-list extended IPSEC-ACL
  permit udp any eq isakmp any eq isakmp
  permit esp any any
class-map IPSEC-CM
  match access-group IPSEC-ACL
policy-map IPSEC-PM
  class IPSEC-CM
    set cos 2
    set dcsp cs2
int <outbound_interface>
  service-policy output IPSEC-PM
More information can be found here:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/3se/qos/configuration_guide/b_qos_3se_3850_cg/b_qos_3se_3850_cg_chapter_011.html#d9712e7502a1635
cheers,
Seb.
5 Replies 5
Seb Rupik
Hi Bob,
Try the following:
  permit esp any any
class-map match-all IPSEC-CM
  match access-group name IPSEC-ACL
policy-map type qos IPSEC-PM
  class IPSEC-CM
    set cos 2
    set dscp cs2
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/QoS_SRND/QoS-SRND-Book/IPSecQoS.html
cheers,
Seb.
Hi Seb,
Thanks for writing!
My IOS doesn't have type qos under policy-map.  Here's what it DOES have.  None seem to lead to type QoS.  I'm using IOSXE  03.16.03.S
  access-control
  appnav
  control
  inspect
  packet-service
  performance-monitor
  service
  service-chain
Thanks!
Hi Bob,
  permit esp any any
class-map IPSEC-CM
policy-map IPSEC-PM
  class IPSEC-CM
    set cos 2
    set dcsp cs2
cheers,
Seb.
Thanks Seb, I tried that and can confirm: your recommendations worked, including the IOSXE modification.
Joseph W. Doherty
Most Cisco devices will copy a packet's ToS to the tunnel packet's ToS. So if you tag your packets as they enter the tunnel, the ToS should be copied.
Or, as an alternative, you might tag your tunnel packets as they pass out the physical egress interface. The difference with the latter, the tunnel packet's ToS can have a different marking from the original packet's.
Either of the above can be done by using a CBWFQ policy attached to an interface.
