Can ping from router but unable to ping from client machines
kaushal
Hi All,
I am having a weird issue with my Cisco 7200 router. From the router i am able to ping and reach out to the internet but from the client i am able to reach out to the internet but unable to ping I am not sure where is the issue but when i traceroute to it my packets are dropped at my routers interface. All my pings from the client time out. I checked the Access list to make sure ICMP is not blocked.
Following is my running conf
ip audit notify log
ip audit po max-events 100
ip ssh break-string ~
ipv6 unicast-routing
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
no voice hpi capture buffer
no voice hpi capture destination
interface Loopback0
description *** abc ***
ip address 192.168.2.2 255.255.255.255
interface FastEthernet0/0
description * Connection to officeswitch *
ip address 10.0.2.1 255.255.255.240
duplex full
speed 100
ipv6 rip abc enable
no ipv6 mfib fast
interface FastEthernet0/1
description * ISP1 *
ip address 172.16.17.2 255.255.255.248
ip access-group ISP1-IN in
ip access-group ISP1-OUT out
ip route-cache flow
duplex full
speed auto
interface Serial3/0
description * ISP2 *
ip address 10.23.21.2 255.255.255.252
ip access-group Verio-IN in
ip access-group Verio-OUT out
ip route-cache flow
serial restart-delay 0
interface Serial3/1
no ip address
shutdown
interface Serial3/2
no ip address
shutdown
interface Serial3/3
no ip address
shutdown
router ospf 00000
log-adjacency-changes
network 192.168.0.0 0.0.31.255 area 0
default-information originate
router bgp 00000
no synchronization
bgp log-neighbor-changes
network 192.168.0.0.0 mask 255.255.224.0
aggregate-address 192.168.0.0 255.255.224.0 summary-only
no auto-summary
ip classless
ip flow-export source Loopback0
ip flow-export version 5
ip flow-aggregation cache protocol-port
enabled
ip flow-aggregation cache prefix
enabled
no ip http server
no ip http secure-server
ip as-path access-list 5 permit ^$
ip as-path access-list 5 deny .*
ip as-path access-list 10 permit ^$
ip as-path access-list 20 permit ^00000
ip as-path access-list 30 permit ^00000
ip access-list standard Access
permit 192.168.0.0 0.0.31.255
deny   any log
ip access-list extended ISP1-IN
permit tcp host 192.168.1.2 any eq www log
permit icmp any any log
deny   ip 10.0.0.0 0.255.255.255 any log
deny   tcp any any eq ftp log
deny   tcp any any eq smtp log
deny   tcp any any eq 443 log
deny   ip 192.168.0.0 0.0.255.255 any log
  permit ip any any
ip access-list extended ISP1-OUT
permit ip any any
ip access-list extended ISP2-IN
  permit ip any any
ip access-list extended ISP2-OUT
permit ip any any
permit icmp any any
logging trap debugging
logging source-interface Loopback0
snmp-server community apricot RO 1
snmp-server trap-source Loopback0
snmp-server location 101 S Ellsworth Ave Suite 350
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps config
snmp-server enable traps envmon fan shutdown supply temperature
snmp-server enable traps bgp
redistribute static
route-map ISP1PATH permit 5
match as-path 30
route-map ISP1PATH permit 10
match as-path 20
set as-path prepend 00000
route-map SETPATH permit 10
match as-path 10
set as-path prepend 00001
I will appreciate any input to help me solve this problem.
mahmoodmkl
Level 7
Level 7
can you please specify which subnet belongs to the client.
In addition i dont see any config relating to NAT in your router.
Thanks for replying. Ours is a very small environment and we use public IP's for clients too thats why there is no NAT related config. The running config i have posted above is real but i have replaced public IP's with private IP's.
Router subnet: 192.168.1.1/28
Client subnet: 192.168.10.1/24
Did you see anything in the Access list which might be causing this issue?
