can ping internet from Router1945K but can not ping from host connected to G0/0
rsardinha
I mount this scenario before going to production.
The host A is connected to int G 0/0 of Router 1945 but cant ping to internet, from router can ping 8.8.8.8, ping host A, ping ISP modem connected to int G 0/1, so need some help to understand whats wrong (sorry for my english).
Thanks for help
RouterDigitel#sh config
Using 1302 out of 262136 bytes
! Last configuration change at 23:13:16 UTC Fri Feb 7 2020 by televen
version 15.0
service password-encryption
hostname RouterDigitel
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
! card type command needed for slot/vwic-slot 0/1
no aaa new-model
no ipv6 cef
ip source-route
ip cef
ip domain name www.xxxx.com
license udi pid CISCO1941/K9 sn
username xxxxx privilege 15 secret 5
interface GigabitEthernet0/0
description CONEXION DIGITEL
ip address 192.168.61.6 255.255.255.252
ip nat inside
ip virtual-reassembly
duplex full
speed 100
no mop enabled
interface GigabitEthernet0/1
ip address 186.167.0.210 255.255.255.248
ip nat outside
duplex full
speed 100
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 186.167.0.209
snmp-server community
control-plane
line con 0
login local
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
end
RouterDigitel#
RouterDigitel#
RouterDigitel#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/28/32 ms
RouterDigitel#sh int
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 4055.3998.30e0 (bia 4055.3998.30e0)
Description: CONEXION DIGITEL
Internet address is 192.168.61.6/30
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:02, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1000 bits/sec, 1 packets/sec
3837353 packets input, 356711010 bytes, 0 no buffer
Received 3678000 broadcasts, 0 runts, 0 giants, 0 throttles
6 input errors, 3 CRC, 2 frame, 0 overrun, 0 ignored
0 watchdog, 17263 multicast, 0 pause input
41312 packets output, 4418317 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
245586 unknown protocol drops
2 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 4055.3998.30e1 (bia 4055.3998.30e1)
Internet address is 186.167.0.210/29
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
5 minute input rate 2000 bits/sec, 5 packets/sec
30617 packets input, 2229054 bytes, 0 no buffer
Received 29524 broadcasts, 0 runts, 0 giants, 0 throttles
2 input errors, 1 CRC, 1 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
10890 packets output, 1271196 bytes, 0 underruns
0 unknown protocol drops
3 lost carrier, 0 no carrier, 0 pause output
NVI0 is up, line protocol is up
Hardware is NVI
Interface is unnumbered. Using address of GigabitEthernet0/0 (192.168.61.6)
MTU 1514 bytes, BW 56 Kbit/sec, DLY 5000 usec,
Encapsulation UNKNOWN, loopback not set
Last input never, output never, output hang never
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
RouterDigitel#
RouterDigitel#
RouterDigitel#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, + - replicated route
Gateway of last resort is 186.167.0.209 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 186.167.0.209
186.167.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 186.167.0.208/29 is directly connected, GigabitEthernet0/1
L 186.167.0.210/32 is directly connected, GigabitEthernet0/1
192.168.61.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.61.4/30 is directly connected, GigabitEthernet0/0
L 192.168.61.6/32 is directly connected, GigabitEthernet0/0
RouterDigitel#
Host A:
C:\Documents and Settings\sistemas>ipconfig
Configuración IP de Windows
Adaptador Ethernet Conexiones de red inalámbricas :
Estado de los medios. . . .: medios desconectados
Adaptador Ethernet Conexión de área local 3 :
Sufijo de conexión específica DNS :
Dirección IP. . . . . . . . . . . : 192.168.61.5
Máscara de subred . . . . . . . . : 255.255.255.0
Puerta de enlace predeterminada : 192.168.61.6
C:\Documents and Settings\sistemas>ping 186.167.0.209
Haciendo ping a 186.167.0.209 con 32 bytes de datos:
Tiempo de espera agotado para esta solicitud.
Estad¡sticas de ping para 186.167.0.209:
Paquetes: enviados = 1, recibidos = 0, perdidos = 1
(100% perdidos),
Control-C
^C
C:\Documents and Settings\sistemas>ping 192.168.61.5
Haciendo ping a 192.168.61.5 con 32 bytes de datos:
Respuesta desde 192.168.61.5: bytes=32 tiempo<1m TTL=128
Estad¡sticas de ping para 192.168.61.5:
Paquetes: enviados = 2, recibidos = 2, perdidos = 0
(0% perdidos),
Tiempos aproximados de ida y vuelta en milisegundos:
M¡nimo = 0ms, M ximo = 0ms, Media = 0ms
Control-C
^C
C:\Documents and Settings\sistemas>ping 192.168.61.6
Haciendo ping a 192.168.61.6 con 32 bytes de datos:
Respuesta desde 192.168.61.6: bytes=32 tiempo<1m TTL=255
Estad¡sticas de ping para 192.168.61.6:
(0% perdidos),
Control-C
^C
Francesco Molino
You're missing the nat statement and acl going with it.
Add this config:
ip access-list extended NAT
permit ip 192.168.61.4 0.0.0.3 any
ip nat inside source list NAT interface g0/1 overload
Then you'll be able to ping internet from your g0/0 and the host sitting in the same subnet.
If you have other subnets behind this g0/0, add them to the acl and you'll be good to go
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
8 Replies 8
Francesco Molino
Add this config:
Francesco
Thanks a lot Francesco,
I'll do after work hours.
To understand your lines:
"ip access-list extended NAT"
I thought that I could use NAT without access list because previous configuration dont has and think that if i dont limit any I could use  ip nat inside  only at the interface.
"permit ip 192.168.61.4 0.0.0.3 any"
What does mean 0.0.0.3 ?
Concerning overload I'm confused because previous configuration dont had but I review this parameter and understand, can use nat without overload?
Well Thanks,  I'll give comments after test,
Ricardo
You have either nat based on acl or static nat.
Can you share the previous config to see what kind of nat you had?
0.0.0.3 is the wildcard mask corresponding to your mask 255.255.255.252.
Good catch from @georg. I answered by looking at your config but didn't look precisely at your host output.
You need to change your router interface mask to 255.255.255.0
Also in the acl the wildcard mask will change from 0.0.0.3 to 0.0.0.255
Francesco
Hi Francesco,
Works great. Thanks a lot.
But try to understand deeper, why previous configuration dont work (without use ACL):
ip nat inside
duplex full
speed 100
no mop enabled
ip nat outside
duplex full
speed 100
It wasn't working because you didn't have any nat statement. You applied nat zone info on interfaces but no nat statement which can be based on an acl or a static nat 1:1
Francesco
on a side note, in addition to what Francesco wrote, your host A has a different subnet mask than the router. Usually that shouldn't be a problem, but it might render unpredictable results. You might want to change either mask to be the same as the other.
The issue is just because of the Private IP being used in the host network .
 192.168.61.6/30
Try pinging the internet using source command with IP on the router facing the host it will not work.
use NAT overload as suggested.
If you want to understand the NAT try going thru the video in the link
https://www.youtube.com/watch?v=xkCgYaJXDSk
Please do not hesitate to click the STAR button if you are satisfied with my answer.
That question was impressive, we are just missing the NAT statement in the configuration.
