Can somebody tell me if something with my NAT isn't working correctly?!
iPhoneFreak
In the attechments you find my whole Network in PacketTracer. Can somebody tell me, if my NAT is working correctly?
It should be very simple, as it is simply about 5 lines of code. The dynamic NAT is working on the R7-Router.
Here the running-config of R7:
R7(config-router)#do show run
Building configuration...
Current configuration : 1030 bytes
version 15.4
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname R7
no ip cef
no ipv6 cef
no ip domain-lookup
spanning-tree mode pvst
interface GigabitEthernet0/0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/1/0
ip address 171.16.0.1 255.255.0.0
ip nat inside
interface Serial0/1/1
ip address 100.0.0.2 255.0.0.0
ip nat outside
clock rate 2000000
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 4.4.4.4
log-adjacency-changes
network 171.16.0.0 0.0.255.255 area 0
network 100.0.0.0 0.255.255.255 area 0
ip nat pool NAT-POOL 100.0.0.3 100.0.0.40 netmask 255.0.0.0
ip nat inside source list 1 pool NAT-POOL
ip classless
ip flow-export version 9
access-list 1 permit 192.168.2.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
login
end
Here the running-config of R8:
R8(config-router)#do show run
Current configuration : 918 bytes
version 15.4
hostname R8
no ip cef
no ipv6 cef
no ip domain-lookup
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
ip address 171.16.0.2 255.255.0.0
clock rate 2000000
no ip address
clock rate 2000000
shutdown
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 5.5.5.5
passive-interface GigabitEthernet0/0/0
network 192.168.2.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
16 Replies 16
the configuration of R7 does not look right. What are you trying to accomplish ?
ip nat inside
If you want NAT to work, the access list (1) needs to match the IP address space of the 'ip nat inside', 171.16.0.1/16 in this case.
So if you change access list 1 to:
access-list 1 permit 171.16.0.1 0.0.255.255
the NAT should work.
First I wanna say thanks to you Georg! :-)
I appreciate your help.
I'm simply trying to accomplish NAT the way it should always work. You have an inside network and an outside network. The inside network addresses should be translated into the outside network adresses (as far as I understand!).
Georg, you mean 172.16.0.0 for the ip access-list, or? Not 172.16.0.1, or do I missunderstand something?
Thx,
Raffael
the access list needs to match the subnet of the inside interface. 172.16.0.0 is not configured on your router, make sure you did not accidentally use 171 instead of 172. The below access list should work:
ip nat inside
access-list 1 permit 171.16.0.0 0.0.0.255
I did what you said, Georg, but I simply do not get any information output, when I write: do show ip nat translations into the console. Do you have any suggestions, why this does not work?
can you post the (zipped) Packet Tracer project (.pkt) file here ?
Here we go! ;-)
Thx Georg!
the access list is still wrong.
You have:
You need:
access-list 1 permit 171.16.0.0 0.0.255.255
I have changed the access list in the attached file. Now if you send a ping from R8 to 192.168.1.66, the translation on R7 is visible:
R7#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 100.0.0.3:1 171.16.0.2:1 192.168.1.66:1 192.168.1.66:1
icmp 100.0.0.3:2 171.16.0.2:2 192.168.1.66:2 192.168.1.66:2
icmp 100.0.0.3:3 171.16.0.2:3 192.168.1.66:3 192.168.1.66:3
icmp 100.0.0.3:4 171.16.0.2:4 192.168.1.66:4 192.168.1.66:4
icmp 100.0.0.3:5 171.16.0.2:5 192.168.1.66:5
But isn't it also possible to use the access-list 1 like this:
Because then the result of show ip nat translations looks like this:
R7#show ip nat translations
icmp 100.0.0.3:1 192.168.2.2:1 192.168.1.195:1 192.168.1.195:1
icmp 100.0.0.3:2 192.168.2.2:2 192.168.1.3:2 192.168.1.3:2
icmp 100.0.0.3:3 192.168.2.2:3 192.168.1.66:3 192.168.1.66:3
icmp 100.0.0.4:1 192.168.2.3:1 172.16.0.3:1 172.16.0.3:1
icmp 100.0.0.4:2 192.168.2.3:2 192.168.1.131:2 192.168.1.131:2
The reason for this question is that I actually want the translations to happen between PC6 & 7 and the other PCs in my topology.
access list 1 permit 192.168.2.0 0.0.0.255
should certainly work.
If you want to migrate from IPv4 to IPv6, I would do it in parallel, meaning, run both at the same time, so you can verify reachability.
Thx Georg! :-)
I think I misread your original post. Not sure why you did not see any NAT translations with access-list 1 permit 192.168.2.0 0.0.0.255. Packet Tracer can be a bit slow or quirky sometimes.
Regarding the IPv6 stuff, let us know if you run into any problems/questions, it should be quite straightforward.
My question is the one below - I repeat it here:
Ok,I have one last question: At the moment I am not able to ping from one IPv6-PC to another IPv6-PC. The packet dies in simulation mode instantly at the PC and does not go further. Does anyone have any suggestion why that is the case and how I can get the PING problem solved?
In the attachment you see my most current state of my project!
on both R9 and R10, add a static default route:
ipv6 route ::/0 serial 0/1/0
Attached the adapted file...
Thx, that was it!
