Can someone explain why .2 /31 can ping and .4/31 cannot ping
hfakoor222
I have 2 routers
RouterA
interface FastEthernet1/0
description Link to AS30
ip address 100.122.1.2 255.255.255.254    (Can ping Router B)
duplex auto
speed auto
Router B
interface FastEthernet0/0
description Link to Central
ip address 100.122.1.3 255.255.255.254
RouterA
ip address 100.122.1.4 255.255.255.254    (Cannot ping Router B)
duplex auto
speed auto
Someone explain this to me please?
Paulo Thame
As you use a /31, it has 0 usable hosts per subnets.
Change the network for /30 , then you will be able to ping then.
this subnet give you 0 host, you can use one side .2/31 other .3/31
or better use /30
https://packetlife.net/blog/2008/jun/18/using-31-bit-subnets-on-point-point-links/
Broadcast address:  100.122.1.3
clarified a lot for me.
Even if it broadcast it can use for p2p link,
Are you check link i attach?
Paulo Thame
