Can't Access Non-Pingable Resources On The Web Through C1700
Keegan Santos
                   Hello Everyone,
Was wondering if someone could help me out, I have a Cisco C1700 doing nat/pat.  since there is only one physical interface on it I have two subinterfaces setup, one thats the inside and one that is the outside and i have a 2950 that i have the main lan switch hooked up to and the cable modem hooked up to.  it works pretty well but for some reason i can't access resources such as web pages and remote desktops on non-pingable client servers and networks.  if i can ping the ip address i can access the resources for example, on two different domains (and ips of course) i have an exchange 2010 server setup.  one of the domains is pingable, the other is not, on the one that is pingable i can access owa without a problem from within my network, but on the one that isn't, i can't access owa, when i know it is accessible becuase i can access it from another network.  if i can provide anymore information let me know.  below are the configs, thank you in advance for any help that ya'll can offer
ROUTER -
Building configuration...
Current configuration : 1622 bytes
version 12.4
hostname rt1
boot-start-marker
boot-end-marker
enable secret 5 $1$7lQ/$5YK9785QnrUoczhF7EgQt1
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp pool trtpool
   network 192.168.176.0 255.255.255.0
   domain-name xxxxxxx
   dns-server X.X.X.X
   default-router 192.168.176.254
ip name-server X.X.X.X
username xxxxx secret 5 xxxxxxxxxxxxxxxxxxxxx
interface FastEthernet0
no ip address
speed auto
interface FastEthernet0.1
encapsulation dot1Q 2
ip address 192.168.176.254 255.255.255.0
ip nat inside
ip virtual-reassembly
no snmp trap link-status
interface FastEthernet0.2
encapsulation dot1Q 1 native
ip address X.X.X.X 255.255.255.252
ip nat outside
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 X.X.X.X
no ip http server
no ip http secure-server
ip nat pool trt X.X.X.X X.X.X.X prefix-length 30
ip nat inside source list 7 pool trt overload
ip nat inside source static tcp 192.168.176.241 3389 X.X.X.X 3389 extendable
access-list 7 permit any
control-plane
line con 0
login local
line aux 0
line vty 0 4
login local
line vty 5 15
login local
end
SWITCH -
Current configuration : 1432 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname sw3
enable secret 5 $1$0jRd$8H/1x37e29qCOLGhr7d6V1
username xxxxxxxxx secret 5 xxxxxxxxxxxxxxxxxxxxxx
ip subnet-zero
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface FastEthernet0/1
switchport access vlan 2
interface FastEthernet0/2
interface FastEthernet0/3
switchport mode trunk
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
spanning-tree vlan 1 cost 19
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan2
ip address 192.168.176.10 255.255.255.0
no ip route-cache
ip http server
line con 0
login local
line vty 0 4
login local
line vty 5 15
login local
end
John Blakley
Keegan,
I'd tighten up the acl that's used for identifying what's being natted. Try this:
no access-list 7
access-list 7 permit 192.168.176.0 0.0.0.255
Unless you're trying to nat out as a certain address, you don't need to use a pool. You could try:
ip nat inside source list 7 interfa f0/0.2 overload
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Yea, I left it like that to eliminate the ACL as a variable.
So you're saying that because I'm using a pool is the reason that its not working?
