DMVPN questions
carl_townshend
Hi all
Im looking at creating a dual hub DMVPN spoke to spoke design for resiliency
I see there are 2 options? single cloud and dual cloud?
what is the difference and why would I use one over the other?
does the dual cloud model have 2 tunnels on the spoke site?
cheers
Carl
JohnTylerPearce
Level 7
Level 7
Carl,
I dont' have any professional experience with DMVPN, but from my undersatnding a dual cloud setup, allows two DMVPN networks using two separate address spaces.
For instance once "cloud" could have 10.0.0.0/24 between hub(s) and spoke(s) and the other "cloud" could have 192.168.1.0/24 between hub(s) and spoke(s).
If I were to create a DMVPN network, I would configure a dual hub as well.
This site may help you out.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/WAN_and_MAN/DMVPDG/DMVPN_1.html
Hello, Carl.
Single cloud is needed if you what full-mesh between spokes in DMVPN phase III.
If you won't use full-mesh, but only hub-to-spoke, then I would recommend you dual cloud, as it's easier to support.
PS: could you clarify your requirements including bandwidth, number of spokes and Hubs location[s]?
