can't access other networks from Vlan10 & vlan20 using OSPF
thirumg3
I can't access other networks from vlan10 & vlan 20 but I can access vlan10,vlan 20 from other networks(OSPF routing protocol is used in my all routers).I can ping vlan10&20 from my BRANCH A router but not ping between the Vlan's (10&20).
For your reference
BRANCH_A#sh runn
Building configuration...
Current configuration : 1157 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname BRANCH_A
no ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX101728HF-
spanning-tree mode pvst
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.16.1.5 255.255.255.252
duplex auto
speed auto
interface Ethernet1/0
no ip address
duplex auto
speed auto
interface Ethernet1/0.3
no ip address
interface Ethernet1/0.10
encapsulation dot1Q 10
ip address 10.1.10.2 255.255.255.0
interface Ethernet1/0.20
encapsulation dot1Q 20
ip address 10.1.20.2 255.255.255.0
interface Vlan1
no ip address
shutdown
router ospf 30
router-id 0.0.0.30
log-adjacency-changes
passive-interface Ethernet1/0.10
passive-interface Ethernet1/0.20
network 10.1.0.0 0.0.255.255 area 0
network 172.16.0.0 0.0.255.255 area 0
network 10.0.0.0 0.255.255.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
VLAN10:
VLAN10#sh runn
Current configuration : 1277 bytes
version 12.1
hostname VLAN10
switchport trunk allowed vlan 1,10,20
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 10
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
VLAN20:
VLAN20#sh runn
Current configuration : 1153 bytes
version 12.1
hostname VLAN20
switchport access vlan 20
interface Vlan1
no ip address
shutdown
line con 0
line vty 0 4
login
line vty 5 15
login
end
BRANCH A:
BRANCH_A#sh ip route
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 5 subnets, 2 masks
C 10.1.10.0/24 is directly connected, Ethernet1/0.10
L 10.1.10.2/32 is directly connected, Ethernet1/0.10
C 10.1.20.0/24 is directly connected, Ethernet1/0.20
L 10.1.20.2/32 is directly connected, Ethernet1/0.20
O 10.2.2.0/24 [110/12] via 172.16.1.6, 00:30:44, FastEthernet0/1
[110/12] via 172.16.1.2, 00:30:44, FastEthernet0/0
172.16.0.0/16 is variably subnetted, 6 subnets, 2 masks
C 172.16.1.0/30 is directly connected, FastEthernet0/0
L 172.16.1.1/32 is directly connected, FastEthernet0/0
C 172.16.1.4/30 is directly connected, FastEthernet0/1
L 172.16.1.5/32 is directly connected, FastEthernet0/1
O 172.16.1.8/30 [110/2] via 172.16.1.2, 00:30:54, FastEthernet0/0
O 172.16.1.12/30 [110/2] via 172.16.1.6, 00:30:54, FastEthernet0/1
O 192.168.1.0/24 [110/11] via 172.16.1.6, 00:30:54, FastEthernet0/1
O 192.168.2.0/24 [110/11] via 172.16.1.2, 00:30:54, FastEthernet0/0
BRANCH_A#sh ip prot
Routing Protocol is "ospf 30"
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Router ID 0.0.0.30
Number of areas in this router is 1. 1 normal 0 stub 0 nssa
Maximum path: 4
Routing for Networks:
Passive Interface(s):
Ethernet1/0.10
Ethernet1/0.20
Routing Information Sources:
Gateway Distance Last Update
0.0.0.1 110 00:01:46
0.0.0.4 110 00:01:46
0.0.0.20 110 00:01:47
0.0.0.30 110 00:01:51
Distance: (default is 110)
BRANCH_A#sh ip ospf neigh
Neighbor ID Pri State Dead Time Address Interface
0.0.0.4 1 FULL/BDR 00:00:36 172.16.1.2 FastEthernet0/0
0.0.0.20 1 FULL/BDR 00:00:37 172.16.1.6 FastEthernet0/1
BRANCH_A#show ip ospf database
OSPF Router with ID (0.0.0.30) (Process ID 30)
Router Link States (Area 0)
Link ID ADV Router Age Seq# Checksum Link count
0.0.0.30 0.0.0.30 313 0x80000008 0x00891f 4
0.0.0.20 0.0.0.20 309 0x80000007 0x0091e4 3
0.0.0.4 0.0.0.4 308 0x80000007 0x009213 3
0.0.0.1 0.0.0.1 308 0x80000007 0x006986 3
Net Link States (Area 0)
172.16.1.5 0.0.0.30 313 0x80000003 0x005b8a
172.16.1.1 0.0.0.30 313 0x80000004 0x00f1f6
172.16.1.13 0.0.0.20 309 0x80000002 0x00b536
172.16.1.9 0.0.0.4 308 0x80000002 0x00838c
You can not ping from VLAN to VLAN because as I see you dont config IP for VLAN (SVI)
and this also need config GW in each PC point to SVI of VLAN in each sites
thirumg3
PFA
balaji.bandi
I want to break down your problem and ask questions here :
I can't access other networks from vlan10 & vlan 20  - what is the other networks ? any IP address ?
but I can access vlan10,vlan 20 from other networks(OSPF routing protocol is used in my all routers) - You can access VLAN 10 and 20, Gateway IP address or end device IP address ( example from what networks you able to access and show some output~) ?
I can ping vlan10&20 from my BRANCH A router but not ping between the Vlan's (10&20). - Branch A having Layer 3 Interface ? are you able to ping end device in that VLAN 10 and 20 ?
have you checked end device have FW
Test output required :
1. Post all the router config - along with show ip route
2. show ip arp from Branch A Router
3. Traceroute from VLAN 10 and 20 output.
4. If you enabled OSPF all Routers as per your diagram,, i am sure i see some OSPF loop here. (on branchA router can you shutdown one of the interface (any one fas 0/0 or fas 0/1 ) do the testings.
5. show ip ospf neigh from all routers.
BB
*ROUTERS: N/T IP*
BRANCH_B -192.168.1.0/24 (192.168.1.2)
BRANCH_C-192.168.2.0/24 (192.168.2.2)
HQ -10.2.2.0/24 (10.2.2.100 , 10.2.2.2.101
,10.2.2.2.200)
[image: image.png]
[image: image.png]
[image: image.png]
I have checked no FW in my end device.
*Test output required
BRANCH_A#sh runn
version 15.1
hostname BRANCH_A
no ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
no ip address
duplex auto
speed auto
no ip address
interface Vlan1
no ip address
shutdown
router ospf 30
router-id 0.0.0.30
ip classless
line con 0
line aux 0
line vty 0 4
login
end
O 10.2.2.0/24 [110/12] via 172.16.1.6, 00:47:23, FastEthernet0/1
[110/12] via 172.16.1.2, 00:47:23, FastEthernet0/0
O 172.16.1.8/30 [110/2] via 172.16.1.2, 00:47:23, FastEthernet0/0
O 172.16.1.12/30 [110/2] via 172.16.1.6, 00:47:23, FastEthernet0/1
O 192.168.1.0/24 [110/11] via 172.16.1.6, 00:47:23, FastEthernet0/1
O 192.168.2.0/24 [110/11] via 172.16.1.2, 00:47:23, FastEthernet0/0
BRANCH_B#sh runn
Current configuration : 860 bytes
version 15.1
hostname BRANCH_B
no ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017QX79-
ip address 172.16.1.6 255.255.255.252
duplex auto
speed auto
ip address 172.16.1.13 255.255.255.252
duplex auto
speed auto
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 20
router-id 0.0.0.20
network 192.168.1.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
BRANCH_B#sh ip route
10.0.0.0/24 is subnetted, 3 subnets
O 10.1.10.0/24 [110/2] via 172.16.1.5, 00:49:53, FastEthernet0/0
O 10.1.20.0/24 [110/2] via 172.16.1.5, 00:49:53, FastEthernet0/0
O 10.2.2.0/24 [110/11] via 172.16.1.14, 00:49:53, FastEthernet0/1
O 172.16.1.0/30 [110/2] via 172.16.1.5, 00:49:53, FastEthernet0/0
C 172.16.1.4/30 is directly connected, FastEthernet0/0
L 172.16.1.6/32 is directly connected, FastEthernet0/0
O 172.16.1.8/30 [110/2] via 172.16.1.14, 00:49:53, FastEthernet0/1
C 172.16.1.12/30 is directly connected, FastEthernet0/1
L 172.16.1.13/32 is directly connected, FastEthernet0/1
192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.1.0/24 is directly connected, Ethernet1/0
L 192.168.1.1/32 is directly connected, Ethernet1/0
O 192.168.2.0/24 [110/12] via 172.16.1.5, 00:49:53, FastEthernet0/0
[110/12] via 172.16.1.14, 00:49:53, FastEthernet0/1
BRANCH_C#sh runn
Current configuration : 858 bytes
version 15.1
hostname BRANCH_C
no ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017Q5R1-
ip address 172.16.1.2 255.255.255.252
duplex auto
speed auto
ip address 172.16.1.9 255.255.255.252
duplex auto
speed auto
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 50
router-id 0.0.0.4
network 192.168.2.0 0.0.0.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
BRANCH_C#sh ip route
O 10.1.10.0/24 [110/2] via 172.16.1.1, 00:51:16, FastEthernet0/0
O 10.1.20.0/24 [110/2] via 172.16.1.1, 00:51:16, FastEthernet0/0
O 10.2.2.0/24 [110/11] via 172.16.1.10, 00:51:16, FastEthernet0/1
L 172.16.1.2/32 is directly connected, FastEthernet0/0
O 172.16.1.4/30 [110/2] via 172.16.1.1, 00:51:16, FastEthernet0/0
C 172.16.1.8/30 is directly connected, FastEthernet0/1
L 172.16.1.9/32 is directly connected, FastEthernet0/1
O 172.16.1.12/30 [110/2] via 172.16.1.10, 00:51:16, FastEthernet0/1
O 192.168.1.0/24 [110/12] via 172.16.1.1, 00:51:16, FastEthernet0/0
[110/12] via 172.16.1.10, 00:51:16, FastEthernet0/1
192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.2.0/24 is directly connected, Ethernet1/0
L 192.168.2.1/32 is directly connected, Ethernet1/0
HQ#sh runn
Current configuration : 899 bytes
version 15.1
hostname HQ
no ip cef
no ipv6 cef
license udi pid CISCO2811/K9 sn FTX1017ZD9L-
ip address 172.16.1.10 255.255.255.252
duplex auto
speed auto
ip address 172.16.1.14 255.255.255.252
duplex auto
speed auto
ip address 10.2.2.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
router-id 0.0.0.1
network 10.2.2.0 0.0.0.255 area 0
ip classless
no cdp run
line con 0
line aux 0
line vty 0 4
login
end
HQ#sh ip route
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
O 10.1.10.0/24 [110/3] via 172.16.1.9, 00:53:24, FastEthernet0/0
[110/3] via 172.16.1.13, 00:53:24, FastEthernet0/1
O 10.1.20.0/24 [110/3] via 172.16.1.9, 00:53:24, FastEthernet0/0
C 10.2.2.0/24 is directly connected, Ethernet1/0
L 10.2.2.1/32 is directly connected, Ethernet1/0
O 172.16.1.0/30 [110/2] via 172.16.1.9, 00:53:24, FastEthernet0/0
O 172.16.1.4/30 [110/2] via 172.16.1.13, 00:53:24, FastEthernet0/1
C 172.16.1.8/30 is directly connected, FastEthernet0/0
L 172.16.1.10/32 is directly connected, FastEthernet0/0
L 172.16.1.14/32 is directly connected, FastEthernet0/1
O 192.168.1.0/24 [110/11] via 172.16.1.13, 00:53:24, FastEthernet0/1
O 192.168.2.0/24 [110/11] via 172.16.1.9, 00:53:24, FastEthernet0/0
*2. show ip arp from Branch A Router:*
BRANCH_A#sh ip arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 172.16.1.1 - 0000.0C9A.1C01 ARPA FastEthernet0/0
Internet 172.16.1.2 55 00D0.9728.9E01 ARPA FastEthernet0/0
Internet 172.16.1.5 - 0000.0C9A.1C02 ARPA FastEthernet0/1
Internet 172.16.1.6 55 0060.3E29.2401 ARPA FastEthernet0/1
*3. Traceroute from VLAN 10 and 20 output:*
[image: image.png]
[image: image.png]
*4. If you enabled OSPF all Routers as per your diagram,, i am sure i see
interface (any one fas 0/0 or fas 0/1 ) do the testings.*
BRANCH_A#conf t
Enter configuration commands, one per line. End with CNTL/Z.
BRANCH_A(config)#int f0/0
BRANCH_A(config-if)#shutdown
%LINK-5-CHANGED: Interface FastEthernet0/0, changed state to
administratively down
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed
state to down
01:12:11: %OSPF-5-ADJCHG: Process 30, Nbr 0.0.0.4 on FastEthernet0/0 from
FULL to DOWN, Neighbor Down: Interface down or detached
BRANCH_A(config-if)#exit
[image: c19213f5-6efb-49b0-b562-adfee5da45d2.png]
[image: image.png][image: 568e10f6-64bc-48ff-88ec-44230ce48953.png]
[image: image.png]
*5. show ip ospf neigh from all routers.*
BRANCH_A>en
0.0.0.20 1 FULL/BDR 00:00:34 172.16.1.6 FastEthernet0/1
BRANCH_A#config t
BRANCH_A(config-if)#no shutdown
%LINK-5-CHANGED: Interface FastEthernet0/0, changed state to up
state to up
BRANCH_A(config)#do sh ip ospf neigh
0.0.0.4 1 2WAY/DROTHER 00:00:36 172.16.1.2 FastEthernet0/0
0.0.0.20 1 FULL/BDR 00:00:30 172.16.1.6 FastEthernet0/1
BRANCH_B#sh ip ospf nei
0.0.0.1 1 FULL/BDR 00:00:34 172.16.1.14 FastEthernet0/1
0.0.0.30 1 FULL/DR 00:00:35 172.16.1.5 FastEthernet0/0
BRANCH_C>en
BRANCH_C#sh ip ospf neig
0.0.0.1 1 FULL/BDR 00:00:31 172.16.1.10 FastEthernet0/1
0.0.0.30 1 FULL/DR 00:00:37 172.16.1.1 FastEthernet0/0
HQ#sh ip ospf nei
0.0.0.4 1 FULL/DR 00:00:32 172.16.1.9 FastEthernet0/0
0.0.0.20 1 FULL/DR 00:00:31 172.16.1.13 FastEthernet0/1
