%SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure con
andresdavid
Hello,  please help me, I posted the whole file with today's logs, I woke up with the system stopped
log:  %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Mar 8 08:45:49.219: SP: SP: Currently running ROMMON from S (Gold) region
*Mar 8 08:46:00.271: %MCAST-SP-6-ETRACK_STATS_LIMIT_EXCEEDED: Number of entries in IGMP snooping explicit-tracking statistics has exceeded the permanent threshold (0)
*Mar 8 08:46:00.271: %MCAST-SP-6-ETRACK_STATS_LIMIT_EXCEEDED: Number of entries in IGMP snooping explicit-tracking statistics has exceeded the maximum limit (0)
*Mar 8 08:46:00.307: %SPANTREE-SP-5-EXTENDED_SYSID: Extended SysId enabled for type vlan. The Bridge IDs of all active STP instances have been updated, which might change the spanning tree topology
*Mar 8 08:46:05.003: %SW_VLAN-SP-6-VTP_DOMAIN_NAME_CHG: VTP domain name changed to NETWORK.
*Mar 8 08:46:09.032: %SYS-SP-5-RESTART: System restarted --
Cisco IOS Software, s72033_sp Software (s72033_sp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 23-Oct-10 02:08 by prod_rel_team
*Mar 8 08:46:09.396: %SYS-SP-6-BOOTTIME: Time taken to reboot after reload = 1498 seconds
*Mar 8 08:46:09: %OIR-SP-6-INSPS: Power supply inserted in slot 1
*Mar 8 08:46:09: %OIR-SP-6-INSPS: Power supply inserted in slot 2
*Mar 8 10:46:09: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 8 10:46:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface Control Plane Interface, changed state to up
*Mar 8 10:46:10: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 10.100.100.6 port 514 started - CLI initiated
*Mar 8 10:46:10: %LINEPROTO-5-UPDOWN: Line protocol on Interface VRF_0_vlan1017, changed state to up
*Mar 8 08:46:09: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
*Mar 8 10:46:11: %SNMP-5-CHASSISALARM: Chassis Alarm Trap: tmpAlarm(OFF), minorAlarm(ON), and/or majorAlarm(OFF)
*Mar 8 10:46:11: %SNMP-5-COLDSTART: SNMP agent on host bb01.network.ro is undergoing a cold start
*Mar 8 10:46:16: %FABRIC-SP-5-CLEAR_BLOCK: Clear block option is off for the fabric in slot 5.
*Mar 8 10:46:16: %FABRIC-SP-5-FABRIC_MODULE_ACTIVE: The Switch Fabric Module in slot 5 became active.
*Mar 8 10:46:17: %DIAG-SP-6-RUN_MINIMUM: Module 5: Running Minimal Diagnostics...
*Mar 8 10:46:29: %LINK-3-UPDOWN: Interface GigabitEthernet5/1, changed state to down
*Mar 8 10:46:29: %LINK-3-UPDOWN: Interface GigabitEthernet5/2, changed state to down
*Mar 8 10:46:29: %SNMP-5-MODULETRAP: Module 5 [Up] Trap
Routing
unfortunately - I was suggesting
12.2.x. SY for Sup2T  and 6T
you have Sup 720 (I do not see any image available to download)
If you looking to keep this chassis some more time in the network - use refurbished cards
Sup2T or Sup6T
to breath some more time.
Cat 6K end of Life
you need to look replace models
Cat 9K
moving forward.
BB
7 Replies 7
balaji.bandi
Can you provide below information :
show version (full)
show modules
BB
andresdavid
balaji.bandi thank you for your reply
show version
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(33)SXI5, RELEASE SOFTWARE (fc2)
Compiled Sat 23-Oct-10 01:30 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
bb01.network.ro uptime is 2 hours, 54 minutes
Uptime for this control processor is 2 hours, 54 minutes
Time since bb01.network.ro switched to active is 2 hours, 52 minutes
System returned to ROM by power cycle at 18:11:38 GMT Wed Mar 8 2023 (SP by power on)
System restarted at 18:36:02 GMT Wed Mar 8 2023
System image file is "disk0:s72033-advipservicesk9_wan-mz.122-33.SXI5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C6509-E (R7000) processor (revision 1.2) with 983008K/65536K bytes of memory.
Processor board ID SMC1028001C
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
70 Virtual Ethernet interfaces
98 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
and  modules:
show module
Mod Ports Card Type Model Serial No.
1 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL13484TNB
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL1310LJL2
5 2 Supervisor Engine 720 (Active) WS-SUP720-3BXL SAD0945029J
7 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL09073NVX
8 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAL08496Y7R
Mod MAC addresses Hw Fw Sw Status
1 c47d.4f0b.eec8 to c47d.4f0b.eedf 4.3 12.2(18r)S1 12.2(33)SXI5 Ok
4 0024.c4a9.0dd0 to 0024.c4a9.0dff 3.0 12.2(18r)S1 12.2(33)SXI5 Ok
5 0011.9202.4504 to 0011.9202.4507 4.3 8.1(3) 12.2(33)SXI5 Ok
7 0013.1972.1b1c to 0013.1972.1b33 2.2 12.2(14r)S5 12.2(33)SXI5 Ok
8 0012.7f69.ead4 to 0012.7f69.ead7 2.0 12.2(14r)S5 12.2(33)SXI5 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAL13484YQD 4.1 Ok
4 Distributed Forwarding Card WS-F6700-DFC3BXL SAD09110DP7 3.4 Ok
5 Policy Feature Card 3 WS-F6K-PFC3BXL SAD0945006F 1.6 Ok
5 MSFC3 Daughterboard WS-SUP720 SAD094506LZ 2.3 Ok
7 Centralized Forwarding Card WS-F6700-CFC SAL09020AZR 2.0 Ok
8 Distributed Forwarding Card WS-F6700-DFC3BXL SAL1033Y52W 5.2 Ok
Mod Online Diag Status
1 Pass
4 Pass
5 Pass
7 Pass
8 Pass
These kit was end of life and support some time back.
at this stage we are not sure what happend - my guess are below .
1. due to long uptime, system may have crashed (look dir - see any crash files)
2. show cpu (check any high CPU at the time of reload if you have any NMS)
3. or high memory use
there is new code last on 12.2.(55?) i think - so upgrade to that code if you still looking to keep this kit.
Most other suggestion, upgrade to latest model to minimise the risk of business loss of services.
Switch come back normal and passed all the tests, so i do not see any issue for now, but keep monitor.
by any chance is this part of VSS ?
BB
andresdavid
I will try to upgrade to 12.2.55 ,
by any chance is this part of VSS ?: no, not part of VSS.
Thanks for all the help.
Sure let us know how it goes and collect more logs (by sending them to Syslog server)
BB
andresdavid
can you help me to download that version 12.2.55 ?
I can't find it anywhere
Sup2T or Sup6T
Cat 6K end of Life
Cat 9K
moving forward.
BB
