can`t access the internet
husseinismael
i am trying to dedicate some traffic to one ISP connection from 1 source IP (10.200.50.2/248)  and the ISP IP is 45.240.181.2.
I can ping from 10.200.50.2 to 45.240.181.2 but I can`t ping the ISP router 45.240.181.1?
here is the router configuration.
interface GigabitEthernet0/0
description connected interface to up-stream SW
mtu 1504
ip address 10.100.129.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip policy route-map CLIENT-ROUTER
duplex auto
speed auto
interface GigabitEthernet0/1
description connected interface to Tunnel SW
ip address 10.100.130.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/2/0
description connected to orange line
ip address 41.128.178.238 255.255.255.248
ip nat outside
duplex auto
speed auto
interface FastEthernet0/3/0
description "connected to ahly bank"
ip address 10.244.243.114 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/3/1
description connected to orange dedicated line
ip address 45.240.181.2 255.255.255.248
ip nat outside
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
no auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 41.128.178.233
ip route 10.200.50.0 255.255.255.248 45.240.181.1
ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/2/0 overload
ip nat inside source list 106 interface FastEthernet0/3/1 overload
access-list 10 permit 10.100.33.0 0.0.0.255
access-list 10 permit 10.100.129.0 0.0.0.255
access-list 105 permit ip 10.244.243.132 0.0.0.3 10.244.243.112 0.0.0.3
access-list 105 deny ip any any
access-list 106 permit ip 10.200.50.0 0.0.0.7 45.240.181.0 0.0.0.7
access-list 106 deny ip any any
route-map CLIENT-ROUTER permit 10
match ip address 105 106
set default interface FastEthernet0/3/0 FastEthernet0/3/1
control-plane
mgcp fax t38 ecm
17 Replies 17
balaji.bandi
This should be next hop address not the interface IP config.
Look at the some example config for guidelines  :
https://community.cisco.com/t5/routing/dual-wan-for-inside-server-by-static-nat-and-pbr/td-p/1610915
BB
41 is another ISP connection, my problem is I cant route dedicated traffic from 10.200.50.2 to 45.240.181.1
I am not really clear on the logic of your policy routing. Which source/destination traffic needs to go to 45.240.181.1 (which is I suppose the next hop) ?
Either way, try the next-hop option on your route map:
set ip next-hop 45.240.181.1
with the below configuration I can ping 45.240.181.1 from 10.200.50.2 but I cant access the internet
mtu 1504
ip nat inside
duplex auto
speed auto
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
no auto-summary
ip http server
I think you want use some kind of pbr and reachability?
If that what looking for
Use pbr with verify availability feature.
You need
NAT with route map
Remember internet use public ip so you need nat your private ip but
Since you have PBR then you need
Nat with route map,
Route map use as condition if this traffic and if this outlet interface then use this nat otherwise use defualt.
can you advice how to do that
not solved. the problem is the router is not translating the IP from private to public.
can I see last config ?
here it is. note that i need the hosts in this network 10.200.50.0/29 to use the internet network 45.240.181.1 as a dedicated.
mtu 1504
ip nat inside
duplex auto
speed auto
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
no auto-summary
ip http server
10.200.50.0/29<- this subnet is direct connect ? where is the interface it connect to??
you need static route toward interface connect to this subnet
match ip address 106
set interface FastEthernet0/3/0
route-map CLIENT-NAT permit 10
match interface FastEthernet0/3/0
access-list 106 permit ip 10.200.50.0 0.0.0.7 any
access-list 10 deny 10.200.50.0 0.0.0.7 any
ip nat inside source route-map CLIENT-NAT interface FastEthernet 0/3/0 overload
note:-
all traffic will flow through 0/2/0 expect 10.200.50.0
there is no failover from 0/2/0 to 0/3/0
I did that and still can't access the internet however I can ping from 10.200.50.2 to 45.240.181.1 !
mtu 1504
ip nat inside
duplex auto
speed auto
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
duplex auto
speed auto
ip nat outside
duplex auto
speed auto
router rip
version 2
network 10.0.0.0
no auto-summary
ip http server
ip nat inside source route-map CLIENT-NAT interface FastEthernet0/3/1 overload
match interface FastEthernet0/3/1
