Can't build EIGRP with Port-Channel sub interfaces and HSRP
Wan_Whisperer
I have two routers configured for HSRP.  The interfaces connecting to the Switch is using subinterfaces.  see below
R1
int f0/1.2
description Vlan2
encapsulation dot1Q 2
ip address 192.168.2.2 255.255.255.0
standby 2 ip 192.168.2.1
standby 2 timers msec 200 msec 650
standby 2 priority 150
standby 2 preempt delay reload 99
standby 2 name Vlan55
standby 2 track 1 decrement 60
int f0/1.3
description Vlan3
encapsulation dot1Q 3
ip address 192.168.3.2 255.255.255.0
standby 3 ip 192.168.3.1
standby 3 timers msec 200 msec 650
standby 3 priority 150
standby 3 preempt delay reload 99
standby 3 name Vlan56
standby 3 track 1 decrement 60
R2
int f0/1.2
description Vlan-2
ip address 192.168.2.3 255.255.255.0
standby 2 name Vlan2
int f0/1.3
description Vlan-3
ip address 192.168.3.3 255.255.255.0
standby 3 name Vlan3
The switch interface is set to trunk and the above setup works.  R1 and R2 have an EIGRP relationship and HSRP is communicating and working as desired.
I would like to use a port channel on each router using two interfaces for many reasons to replace the single interface that is currently working.  See the configs below:
R1
Int f0/0
Channel-group 1
Int f0/1
Channel-group 1
int p1.2
description Vlan2
int p1.3
description Vlan3
R2
Int f0/0
Channel-group 1
Int f0/1
Channel-group 1
int p1.2
description Vlan-2
int p1.3
description Vlan-3
The above does not work.  EIGRP does not attempt to build and HSRP does not work.  Any thoughts?
Hello
Your configuration seems correct, it could be down to the simulation software you are using?
Also
when you create aggregation ports the creation of those ports differs depending on its a L2 or L3 PC
L2 = Create the logical PC interface by assigning the aggregation first on the physical interfaces
L3 = Create the logical PC interface manually and then attach the physical interfaces
See attached a working CFG file using rtr CSR1000V 16.06.01 and sw vios_l2 Version 15.2
Kind Regards
Paul
11 Replies 11
show etherchannel summary
check if both member port is Pending and the Port-channel is SU or RU ?
balaji.bandi
You have provided the information on the R1 and R2, can you provide the information on switch side also?
also provide
show etherchannel 1 summary
show ip interface brief
show vlan
BB
After running the command
on the router it looks like port-Channel 1 is not building.  I ran
debug etherchanel
***see results at the bottom of this post.***
R1#sho ip int b
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES NVRAM  up                    up
FastEthernet1/0            unassigned      YES NVRAM  up                    up
Port-channel1              unassigned      YES unset  up                    up
Port-channel1.2            192.168.2.2     YES manual up                    up
Port-channel1.3            192.168.3.2     YES manual up                    up
R1#     show etherchannel 1 summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        R - Layer3      S - Layer2
        U - in use
Group Port-channel  Ports
R1#sho int p1
Port-channel1 is up, line protocol is up
  Hardware is FEChannel, address is c402.4e84.0010 (bia 0000.0000.0000)
  MTU 1500 bytes, BW 200000 Kbit/sec, DLY 100 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
    No. of active members in this channel: 2
        Member 0 : FastEthernet1/0 , Full-duplex, 100Mb/s
        Member 1 : FastEthernet0/0 , Full-duplex, 100Mb/s
    No. of Non-active members in this channel: 0
    No. of PF_JUMBO supported members in this channel : 0
  Last input never, output never, output hang never
  Input queue: 0/150/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/80 (size/max)
  5 minute output rate 5000 bits/sec, 11 packets/sec
     0 packets input, 0 bytes
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     54777 packets output, 3639114 bytes, 0 underruns
     0 unknown protocol drops
     0 lost carrier, 0 no carrier
R1#sho int f0/0
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is c402.4e84.0010 (bia c402.4e84.0000)
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:55, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:55:04
  Output queue: 0/40 (size/max)
  5 minute output rate 5000 bits/sec, 10 packets/sec
     55 packets input, 19800 bytes
     Received 55 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     34859 packets output, 2332538 bytes, 0 underruns
R1#sho int f1/0
FastEthernet1/0 is up, line protocol is up
  Hardware is AmdFE, address is c402.4e84.0010 (bia c402.4e84.0010)
  Last input 00:00:00, output 00:00:08, output hang never
  Last clearing of "show interface" counters 01:28:30
     76 packets input, 27360 bytes
     Received 76 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     5039 packets output, 355468 bytes, 0 underruns
S1#sho ip int b
FastEthernet3/12           unassigned      YES unset  up                    up
FastEthernet3/13           unassigned      YES unset  up                    up
FastEthernet3/14           unassigned      YES unset  up                    up
FastEthernet3/15           unassigned      YES unset  up                    up
Port-channel2              unassigned      YES unset  up                    up
Vlan1                      unassigned      YES NVRAM  up                    up
Vlan2                      unassigned      YES unset  up                    up
Vlan3                      unassigned      YES unset  up                    up
S1#    sho run int f3/12
Building configuration...
Current configuration : 106 bytes
interface FastEthernet3/12
 switchport mode trunk
 duplex full
 speed 100
 channel-group 1 mode on
end
S1#    sho run int f3/13
interface FastEthernet3/13
 duplex full
 speed 100
end
S1#    sho run int f3/14
interface FastEthernet3/14
 duplex full
 speed 100
 channel-group 2 mode on
end
S1#    sho run int f3/15
interface FastEthernet3/15
 duplex full
 speed 100
S1#sho int p1
  Hardware is EtherChannel, address is c406.0cb0.f30c (bia c406.0cb0.f30c)
  MTU 1500 bytes, BW 200000 Kbit/sec, DLY 1000 usec,
  Members in this channel: Fa3/12 Fa3/13
     0 packets input, 0 bytes, 0 no buffer
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
R1#debug etherchannel
EtherChannel/PAgP Shim/FEC debugging is on
R1#config t
Enter configuration commands, one per line. End with CNTL/Z.
R1(config)#int range f0/0 , f1/0
R1(config-if-range)#shut
R1(config-if-range)#FastEthernet0/0 taken out of port-channel1
*Mar 1 00:18:18.611: %LINK-5-CHANGED: Interface FastEthernet0/0, changed state to administratively down
*Mar 1 00:18:19.611: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Mar 1 00:18:20.611: %HSRP-5-STATECHANGE: Port-channel1.2 Grp 2 state Active -> Init
*Mar 1 00:18:20.615: %HSRP-5-STATECHANGE: Port-channel1.3 Grp 3 state Active -> Init
*Mar 1 00:18:21.611: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to down
R1(config-if-range)#no shut
%Interface MTU set to channel-group MTU 1500.
FastEthernet0/0 added as member-1 to port-channel1
FastEthernet1/0 added as member-2 to port-channel1
*Mar 1 00:18:50.239: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Mar 1 00:18:50.247: %LINK-3-UPDOWN: Interface FastEthernet1/0, changed state to up
*Mar 1 00:18:51.239: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Mar 1 00:18:51.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/0, changed state to up
*Mar 1 00:18:53.239: %LINEPROTO-5-UPDOWN: Line protocol on Interface Port-channel1, changed state to up
*Mar 1 00:18:54.547: %HSRP-5-STATECHANGE: Port-channel1.2 Grp 2 state Speak -> Standby
*Mar 1 00:18:54.547: %HSRP-5-STATECHANGE: Port-channel1.3 Grp 3 state Speak -> Standby
*Mar 1 00:18:54.579: %HSRP-5-STATECHANGE: Port-channel1.2 Grp 2 state Standby -> Active
*Mar 1 00:18:54.583: %HSRP-5-STATECHANGE: Port-channel1.3 Grp 3 state Standby -> Active
i see it work now ? am I right ?
No,  the port channel on the Routers and not building
        U - in use
are SW use LACP or you use mode ON ?
before we go further is this in the Lab simulator ?
1. make sure check interface mapping correctly to right port example :
port-channel1 switch1 going to router1 ports
port-channel2 switch1 going to router2  ports
as suggested both the side should be LACP or Mode on.
BB
There was quite a bit of output from R1 and it looked pretty good. I would like to see similar output from R2. My guess is that the issue is something on R2.
Rick
Hello
Also
Kind Regards
Paul
Paul,
Because you got it working with my configs I am just going to assume it's related to GNS3.  I will test the configs on my real environment in a few weeks.
WW
friend still you not answer me are you use mode ON or ACVTIVE ??
this inform is important, as I can see from your config you only config
channel-group 1
<< without mode ?
