can't find flash on 2651XM
henrybb
I can't find flash on my 2651XM. And I don't know what's wrong with it.
Can u help me ? thanks!
RT2651A#sh flash
% Invalid input detected at '^' marker.
RT2651A#sh f?
file frame-relay
RT2651A#sh region
Region Manager:
Start End Size(b) Class Media Name
0x07C00000 0x07FFFFFF 4194304 Iomem R/W iomem
0x60000000 0x61FFFFFF 33554432 Flash R/O flash
0x80000000 0x87BFFFFF 130023424 Local R/W main
0x80008098 0x80ED1543 15504556 IText R/O main:text
0x80ED1544 0x81633F87 7744068 IData R/W main:data
0x81594F28 0x81633F87 651360 Local R/W data:firmware
0x81633F88 0x818710AB 2347300 IBss R/W main:bss
0x818710AC 0x87BFFFFF 104394580 Local R/W main:heap
RT2651A#sh ver
IOS (tm) C2600 Software (C2600-IPBASE-M), Version 12.3(6e), RELEASE SOFTWARE (f)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Fri 01-Apr-05 03:01 by hqluong
Image text-base: 0x80008098, data-base: 0x80ED1544
ROM: System Bootstrap, Version 12.2(8r) [cmong 8r], RELEASE SOFTWARE (fc1)
ROM: C2600 Software (C2600-IPBASE-M), Version 12.3(6e), RELEASE SOFTWARE (fc3)
RTFS2651A uptime is 3 hours, 52 minutes
System returned to ROM by reload
System image file is "flash:c2600-ipbase-mz.123-6e.bin"
cisco 2651XM (MPC860P) processor (revision 0x401) with 126976K/4096K bytes of m.
Processor board ID FHK0845U01N (1184707748)
M860 processor: part number 5, mask 2
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
Basic Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
1 ISDN Basic Rate interface(s)
2 Channelized E1/PRI port(s)
32K bytes of non-volatile configuration memory.
b-ulrich
Level 3
Level 3
That is interesting. May be the IOS you are running. Try a 'dir' to see what directories you have listed, then change directories to look for the flash: file system.
thanks for your reply and I can't see any information for the command.
RT2651A#dir
%Error parsing (Bad file number)
