03-12-2014 11:37 AM - edited 03-04-2019 10:33 PM
I bought Cisco WIC-2A/S Wan Interface Cards http://www.ebay.com/itm/161087476330?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649 and I can't get the line nor the protocol up on these cards.
Isn't the light supposed to come on when I connect the serial cable (there is no light)? I am using these cables that I also just bought http://www.ebay.com/itm/310869808480?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649. I took the cables to school and they worked fine, but not on my home network.
At the interface, I "no shut” the ports on the two connected routers over and over, but it still shows down/ down. I have quadruble checked myself that I have the cables in the correct ports – I take my diagram with me when I check the connections and look at it when I am at the command prompt configuring the ports.
I've set the clock rate on the DCE interface, but no clock shows up in show run; I tried setting it to a slower rate, but still nothing in show run, just the ip.
I've tried switching out the cables.
I have one card in a 2651 XM running IOS version 12.3 and one in a 2610 running IOS version 12.2. The Ethernet ports on these are running fine.
I have both ends set to the same network 192.168.3.1 & 2/24. I've set them both to Router RIP v2 and set them two advertise their networks, but with the serial ports down, they of course have not shared advertisements.
03-12-2014 02:47 PM
