Can't get SMTP to bypass ASA5510
dclarolh1
I have a one to one nat setup and access lists configured. I can't seem to be able to translate any port. Something must be wrong...
Here is my config:
ASA Version 8.2(2)19
hostname *****-DC-SR1-5510-1
domain-name ***.local
enable password ds4hdW4uvMnfKnfo encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 10.245.2.0 ***LAN description 10.245.2.x
name 10.245.2.14 ****vox description Phone System
name x.x.156.154 mchamberland description Mike's Static Home IP
name 10.245.50.0 VPNLAN
name 10.245.253.1 Inside
name 10.245.2.25 ***AD01 description Radius Server 1
name x.x.102.142 Outside_SIP
name x.x.60.91 Outside_SIP_Gateway description Fiber
name 10.245.2.44 Internal_SMTP_Server
name x.x.102.131 External_SMTP_Server
interface Ethernet0/0
description Fiber
nameif outside
security-level 0
ip address x.x.102.130 255.255.255.240
interface Ethernet0/1
description Cable
shutdown
nameif Outside2
security-level 0
ip address dhcp setroute
interface Ethernet0/2
nameif inside
security-level 100
ip address Inside 255.255.255.0
interface Ethernet0/3
shutdown
nameif Inside2
security-level 100
no ip address
interface Management0/0
nameif management
security-level 100
ip address 10.245.1.2 255.255.255.0
management-only
boot system disk0:/asa822-19-k8.bin
ftp mode passive
dns server-group DefaultDNS
same-security-traffic permit inter-interface
object-group service RTP udp
port-object range 10000 20000
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
object-group network Outside_SIP_Group
description SIP Acces to *****vox
network-object host mchamberland
network-object host Outside_SIP_Gateway
access-list outside_access_in extended permit icmp ***LAN 255.255.255.0 any echo-reply
access-list outside_access_in extended permit esp ***LAN 255.255.255.0 host x.x.182.76
access-list outside_access_in extended permit udp ***LAN 255.255.255.0 eq isakmp host 64.85.182.76
access-list outside_access_in extended permit udp ***LAN 255.255.255.0 eq 4500 host 64.85.182.76
access-list outside_access_in extended permit udp ***LAN 255.255.255.0 eq 1701 host 64.85.182.76
access-list outside_access_in extended permit tcp any eq smtp host External_SMTP_Server eq smtp
access-list outside_access_in extended permit ip object-group Outside_SIP_Group host *****vox
access-list outside_access_in extended permit tcp any any eq telnet
access-list ***VPN_splitTunnelAcl standard permit ***LAN 255.255.255.0
access-list ***VPN_splitTunnelAcl standard permit 10.245.253.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip ***LAN 255.255.255.0 VPNLAN 255.255.255.0
access-list inside_access_out extended deny tcp any any eq telnet
pager lines 24
logging enable
logging timestamp
logging trap notifications
logging asdm informational
logging host inside 10.245.2.21
mtu outside 1500
mtu Outside2 1500
mtu inside 1500
mtu Inside2 1500
mtu management 1500
ip local pool ***VPNPOOL 10.245.50.50-10.245.50.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-632.bin
no asdm history enable
arp timeout 14400
global (outside) 101 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 101 0.0.0.0 0.0.0.0
static (inside,outside) Outside_SIP *****vox netmask 255.255.255.255
static (outside,inside) *****vox Outside_SIP netmask 255.255.255.255
static (inside,outside) External_SMTP_Server Internal_SMTP_Server netmask 255.255.255.255
access-group outside_access_in in interface outside
access-group inside_access_out out interface inside
route outside 0.0.0.0 0.0.0.0 x.x.102.129 1
route inside 10.245.1.0 255.255.255.0 10.245.253.2 1
route inside ***LAN 255.255.255.0 10.245.253.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server Radius protocol radius
aaa-server Radius (inside) host ***AD01
key *****
radius-common-pw *****
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http ***LAN 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map type inspect sip Default
parameters
  max-forwards-validation action drop log
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect pptp
  inspect sip
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:a5a816524a34b550a467e0c7e0c48c90
: end
8 Replies 8
Is this what you're referring to?
In order to reach the SMTP server from the outside you need to do the following:
no access-list outside_access_in extended permit tcp any eq smtp host External_SMTP_Server eq smtp
access-list outside_access_in extended permit tcp any host External_SMTP_Server eq smtp
If you see, I changed the source port on the ACL from SMTP to any.
This is because if you want to reach the SMTP server from the outside, the destination port is TCP 25, but the source port is unknown.
Try the above and let us know.
Federico.
That's the entries...
Made the change, at least I am getting hits on the ACL now. The problem is I am getting denied by my inside_access_out ACL's. So confusing...
Here is the error(I am running the SMTP test from mxtoolbox.com):
4Nov 09 201008:27:2164.20.227.13350714External_SMTP_Server25Deny tcp src outside:64.20.227.133/50714 dst inside:External_SMTP_Server/25 by access-group "inside_access_out" [0x0, 0x0]
The outbound traffic is controlled by the inside_access_out ACL.
There's only one statement in it and it's a deny rule, this means no outbound traffic is permitted.
You should include permit statements in that ACL to allow outgoing traffic.
For example to allow IP access outbound from the SMTP server:
access-list inside_access_out permit ip host SMTP_SERVER any
Federico.
this is in:
access-list inside_access_out extended permit ip host Internal_SMTP_Server any
now I am getting this error:
4Nov 09 201009:19:5664.20.227.13354914External_SMTP_Server25Deny tcp src outside:64.20.227.133/54914 dst inside:External_SMTP_Server/25 by access-group "inside_access_out" [0x0, 0x0]
There's something wrong here:
You're attempting a connection from the outside (inbound) and the error is by the ACL applied to the inside interface.
Can you please post the following:
sh run static
sh run access-list
sh run access-group
Federico.
Tell me about it, it's confusing me to no end...
Here's the output:
sh run static
static (inside,outside) tcp External_SMTP_Server smtp Internal_SMTP_Server smtp netmask 255.255.255.255
static (inside,outside) Outside_SIP Switchvox netmask 255.255.255.255
static (outside,inside) Switchvox Outside_SIP netmask 255.255.255.255
sh run access-list
access-list outside_access_in extended deny tcp any any eq telnet
access-list inside_access_out extended deny tcp any eq telnet any eq telnet
sh run access-group
Yes, the error is not correct with the config, but let's do the following:
packet-tracer input outside tcp 64.20.227.133 1024 External_SMTP_Server 25 det
Or via ASDM you can do it.... to simulate the connection to see if you get the same report from the ASA.
Federico.
sh run access-group
The above output says you have access list inside_access_out in OUT direction which is blocking the traffic ,
do this :-
no access-group inside_access_out out interface inside
access-group inside_access_out in interface inside
Manish
