Can't Ping connected dialer IP on cisco 4g wireless 819 router
kdsingh007
Hi all,
I have cisco router model (C819HG-LTE-MNA-K9 chassis) and have working sim in it, cellular interface and dialer interface is up but I cant ping my connected dialer IP. ping fails, what could be the reason?
cisco_WTL#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S* 0.0.0.0/0 is directly connected, Dialer1
10.0.0.0/32 is subnetted, 1 subnets
C 10.0.0.11 is directly connected, Loopback100
192.168.2.0/32 is subnetted, 1 subnets
C 192.168.2.81 is directly connected, Dialer1
cisco_WTL#ping 192.168.2.81 source dialer 1
Sending 5, 100-byte ICMP Echos to 192.168.2.81, timeout is 2 seconds:
Packet sent with a source address of 192.168.2.81
Success rate is 0 percent (0/5)
7 Replies 7
ping interface use same interface I dont think this work
use only
ping 192.168.2.81
that it
MHM
ping 192.168.2.81 doesn't work either
show ip route
check if the IP still same, this PPP so the IP always change
it still is the same IP
Can I see the dialer interface config
MHM
interface Cellular0
ip address negotiated
ip virtual-reassembly in
encapsulation slip
dialer in-band
no dialer string lte
dialer pool-member 1
dialer-group 1
interface Dialer1
encapsulation slip
dialer pool 1
dialer idle-timeout 0
dialer string lte
dialer persistent
dialer-group 1
ip route 0.0.0.0 0.0.0.0 Dialer1
ip tacacs source-interface Dialer1
it seem that PPP dialer interface can not self ping check below link
https://community.cisco.com/t5/routing/does-self-ping-works-on-dialer-interface/td-p/1788304
MHM
