Hide wireless coverage range spinbox
emadhsh
fWhere can I find wireless coverage range spinbox in packet 8.2.1 to hide and show it. Thanks
10 Replies 10
pieterh
your question is not clear to me!
>>>  packet 8.2.1 <<<  => you mean in packet tracer 8.2.1
Yes, I mean in packet tracer version 8.2.1 . thank you for responding
I do not believe Packet tracer has an option to place access-points on a floor-plan and display a heatmap
 here is the option it is found in the option menu then prefrences then hide/show tab in packet tracer ver 8.2.1 and I do not know where is this spinbox
pieterh
I think  need to switch views
this video may explain some options for you
Packet Tracer: Physical Workspace - Using Custom Backgrounds (BG) - YouTube
you are right you have to switch to the physical view . but the question is where in the physical view you can see the effect of show and hide wireless coverage range spinbox. thanks a lot
is the access point already placed in this view ?
and is the scale setup correctly ?
if the scale is set to city-wide than the spinbox is only a few dots -> modify to room scale
Yes the access point already placed in the physical view, but in fact I don't know how to modify the scale to room scale.
did you look at the video ?
it is explained  at 1:53 / 2:28
first, I would like to thank you for your help. After I saw the video, I modified the scale to room scale, but I didn't see the wireless coverage range spinbox only I could see the boundary and the gradient color of the wireless signal of the access point.
