Can't ping from one network to another. Please help
Pilder1
Hello everyone,
I need some guidance on pinging from router 1 to router 2 and 3 and viceverse. I've been struggling pinging from PC Admin in Office 3 to CEO1 in Office 1, I have looked for all connections and looked for all possible missed commands and subnet masks, I have done everything in my knowledge, even though I can't reach connectivity from one network to another.
Attached please find the topology I've been working with, so you can take a look and correct me from my mistakes.
Thank you all.
What are the enable passwords for your routers ?
You need routing on your routers, either static or dynamic. The easiest would be to configure the below
on all three routers:
router eigrp 1
network 0.0.0.0
no auto-summary
Also, it looks like you have a duplicate IP address:
R3
interface Serial0/0/0
ip address 172.16.10.98 255.255.255.224
R2
ACDC1973
beatles1960
Thank you.
there were numerous mistakes in your network configuration:
1. All IP addresses and default gateways of all PCs were wrong. I added DHCP pools on the routers, so the attached devices get the correct addresses.
2. The trunk between the switch and the router had a native Vlan of 100. This kept the trunk from transmitting any traffic. If you want to set the native Vlan to 100, you need a matching subinterface on the router. I set the trunk to the default (native Vlan 1).
3. I corrected the duplicate IP address between R3 and R2.
4. I removed all port security from the access ports
5. I assigned static IP addresses to both servers.
Attached the working file with end to end connectivity (saved in PT version 7.3.1).
