Cant set both static pat and nat overload same time
raresz
Hi. I finally got public IP, so in case of homelab i wanted to push my NextCloud server outside.
What's the problem:
I have almost blank configuration(interfaces, ssh access, dhcp - all works), i need only to have 2 things to be done for now: Static PAT for webserver that redirects port 80 and NAT overload for that all devices in home network has got internet access.
Router: 2851
Since i started trying configurations i can get only 3 states: NAT doesnt work at all, Works port forwarding into webserver but there is no internet access and third one: i have internet access but port forwarding doesn't work.
I have 2 configs where except this what i paste all other things are same everywhere.
interface Gi0/0 : ip nat outside
interface Gi0/1: ip nat inside
Here works: NAT overload
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
Here works: Static PAT
ip nat inside source static tcp 192.168.1.111 22 83.x.y.z 22 extendable
ip nat inside source static tcp 192.168.1.111 80 83.x.y.z 80 extendable
ip nat inside source static tcp 192.168.1.111 443 83.x.y.z 443 extendable
access-list 102 permit tcp any any
access-list 102 permit tcp any any eq www
access-list 102 permit tcp any any eq 443
access-list 102 permit tcp any any established
access-list 102 permit tcp any any eq 22
access-list 103 permit ip any any
access-list 110 permit tcp any any established
And the goal is to both things work together. Weird thing is even if i started from empty configuration and try to run ONLY static PAT first, typing commands line by line meanwhile checking what is enough to run it - it just didn't worked at all. Only way is to load whole config file. i checked on a computer all rest of config is same in both files.
I'm struggling with that 3rd day and i'm really tired specially every page when i search for "how to" it's only about 2 commands for static PAT and 2 commands for NAT overload. Can somebody help?
P.S. Always, every config it is - always it's apparent static translation while doing: show ip nat translations. So i thought commands for PAT are good just maybe there is a problem with ACL somewhere.
first of all, you don't need the 'extendable' keyword, as this is only required if you want to translate a private IP address to more than one public IP address. Looking at what you have posted, it appears you have only one public IP address ?
You could try the 'combinations' below:
1.
ip nat pool ISP_POOL 83.x.y.z 83.x.y.z netmask 255.255.255.252 <-- make sure the mask matches yours
ip nat inside source list 101 pool ISP_POOL overload
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
2.
ip nat inside source route-map ISP_OUT interface GigabitEthernet0/0 overload
route-map ISP_OUT permit 10
match ip address 101
match interface GigabitEthernet0/0
Hello
Can you share the running config of your router in a file and attach to this please?
Kind Regards
Paul
Hi, i already managed it to work in middle of last night i just made ip
nat pool first and used sequence of pool and access list this time and it
worked.
1.
2.
