Can't Ping from Sub interface of RTR to Access Port on SW but I can ping end points from the SW.
Smorgan
I have a Cisco 2911 RTR Sub-Interface
Interface 0/0.100
 description "Direct Connect to AWS "
 encapsulation dot1Q 100
 ip address X.X.254.4 255.255.255.240
Directly connected to a Cisco 3650
Interface 1/0/23
 description  AWS Connect
 switchport access vlan 100
 switchport mode access
 speed 1000
 duplex full
Interface Vlan 100
IP Address X.X.254.13 0.0.0.15
Interface Vlan 9
IP Address X.X.9.1
End Point in AWS X.X.254.1
With this configuration I can ping from the switch to the 254.1 end point without issue but I can not ping the RTR.
From the RTR I can not ping either the .13 address nor the .1  but I can ping the 9.1 interface. I have a feeling it has to do with routing but Im not sure where to start. Can someone please point me in the right direction?
Muhammad Awais Khan
On switch interface connected to Router, make it trunk port instead of Access. Reason behind is that on Router you have created sub interface with vlan encapsulation 100. We should have also tagged/trunk interface on switch side.
Interface 1/0/23
 No switchport access vlan 100
 No switchport mode access
Switchport mode trunk
Switchport trunk allowed vlan 100
 speed 1000
 duplex full
You can add more VLANS on above switch interface if you create more subinterfaces on Router side. You need to use "switchport trunk allowed vlan add " whenever you add mode vlan on above interface.
Muhammad Awais Khan
Interface 1/0/23
 speed 1000
 duplex full
Or if you don't have any intention add more sub interfaces then you can simplify your configuration by keep the same config on the switch what you have already done.
On Router, delete the sub-interface using " no Interface 0/0.100"
And assign the same IP on Gi 0/0
Interface gi0/0
if you are using a subinterface on the router connected to an access port on the switch, you likely need to add the 'native' keyword:
interface 0/0.100
encapsulation dot1Q 100 native
Hello
I notice you have multiple L3 addressing on the switch  vlan 9, vlan 100  So I would say you wouldn't require sub-interfaces on the rtr, as either the rtr or the switch would provide the L3 inter-vlan routing, So if the switch is providing this then the rtr lan facing interface can be just be an standard port, Also is the rtr it will need to be aware of all the other L3 networks on the switch, does it have route(s) for them?
Kind Regards
Paul
