Can't ping internal network from router
romy786
I can't ping internal network from router although my network is running and all devices can use internet. I am using one router c1801 with three catalyst 3550 switches. Here is my running configuration.
Building configuration...
Current configuration : 1326 bytes
version 12.4
hostname G3R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip name-server 203.128.3.18
ip name-server 203.128.7.10
no ipv6 cef
archive
log config
hidekeys
interface FastEthernet0
ip address 122.129.85.69 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
switchport access vlan 10
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface Vlan1
no ip address
interface Vlan10
ip nat inside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 122.129.85.65
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
login
webvpn cef
end
Hello.
with internal network I assume you mean the 192.168.1.0/24 network ? The router config looks ok, can you post the config of one of the 3550s ?
I agree with Georg that I do not see any obvious issues in the router config. As a first step in investigating this would you provide the output of these steps
1) show arp
2) attempt the ping
3) show arp
Rick
Rick
After posting my first response I have an additional thought. Is it possible that the device on the internal network has a firewall implemented that is not allowing the ping? Can you ping that device from one of the switches or ping from another device in the internal network?
Rick
Rick
