csudsu
rudhsubbu1
hi
i am using two router with csudsu what type of cable is used to connect csudsu wic 1dsu t1 wan port on both routers
is there any difference between crossover cat 5 and crossover cat 5 t1 cable
Richard Burts
Yes there is absolutely a difference between the traditional cat 5 Ethernet cross over cable and a T1 cross over cable. To connect your routers you will need a T1 cross over cable.
Rick
Rick
