Can't ping isp DNS or Internet
tonymlee18
For some reason I can't ping the dns or browse to the Internet.
I have a cisco 851W
I have DSL and setup to dhcp.
When I do a show ip int 4 it shows a ip address picked up for my ISP. So  I know I can get a IP address but I can't ping the DNS which is
72.235.80.12 and 72.235.80.4
Thanks.
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname smithrouter
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 cisco
no aaa new-model
dot11 syslog
dot11 ssid tgsmdinc
authentication open
no ip source-route
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1
ip dhcp pool ccp-pool1
import all
network 192.168.1.0 255.255.255.0
dns-server 72.235.80.12 72.235.80.4
default-router 192.168.1.1
ip cef
no ip bootp server
ip domain name smith.local
ip name-server 72.235.80.12
ip name-server 72.235.80.4
username smith privilege 15 secret 5 cisco
archive
log config
hidekeys
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
bridge irb
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address dhcp client-id FastEthernet4
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
interface Dot11Radio0
no ip address
ssid tgsmdinc
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface BVI1
description $ES_LAN$$FW_INSIDE$
ip nat inside
ip tcp adjust-mss 1412
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 FastEthernet4
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet4 overload
logging trap debugging
access-list 1 remark INSIDE_IF=BVI1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.1.0 0.0.0.255
no cdp run
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Hello Tony,
Can you remove the default route you have in the configuration?
no ip route 0.0.0.0 0.0.0.0 FastEthernet4
Then, bounce the FastEthernet 4 interface. That should allow the ISP to set
the default route.
Hope this helps.
NT
kyukim
Hi, Tony.
If you can't ping your ISP DNS but you can ping ISP default GW, this means your ISP DNS has a problem.
I do see this kind of problem from my ISP too.
Try to use public well known DNS server, like 4.2.2.2.
I usually configure my dhcp server to use one of my ISP dns and secondary as 4.2.2.2
ip name-server 4.2.2.2.
Try to ping 4.2.2.2 from your router. If you can't ping, then your ISP has a problem.
KK
Hi KK
I still can't get out to the Internet.
If I use my other router I can ping both DNS and go to the Internet fine.
I just have this problem with the cisco router.
Any other suggestions?
thanks
btw cant ping 4.2.2.2 either but I can ping the gateway fine.
if i'm on my linksys router I can ping 4.2.2.2 and 72.235.80.12 just fine but not on the cisco router.
Hello Tony,
the default route.
Hope this helps.
NT
wow! thanks! that worked!!!
