Can't Ping outside network
andrewex1
I have a very simple setup.
The router is connected through my fiber internet on fa0/1 using a public ip address. fa0/0 is connected directly to my server. I have setup ip nat to forward my public ip and when I type my public ip address in the URL bar I see Apache. All is good so far.
The issue i am having is getting outbound internet on my server. I think this has to do with adding a access-list.
Any help is appreciaded.
Here is my current config file:
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip name-server 8.8.8.8
ip name-server 8.8.4.4
interface FastEthernet0/0
description internal lan
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description outside world
ip address 68.67.85.80 255.255.255.248
ip access-group 1 out
ip nat outside
duplex auto
speed auto
ip default-gateway 192.168.1.1
ip nat inside source static tcp 192.168.1.100 80 68.67.85.80 80 extendable
ip nat inside source static tcp 192.168.1.100 443 68.67.85.80 443 extendable
ip nat inside source static tcp 192.168.1.100 22 68.67.85.80 22 extendable
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 68.67.85.79
ip dns server
access-list 1 permit any
line con 0
line aux 0
line vty 0 4
login
end
Andrew,
Please refer to my other post in the Web server thread that you had going the other day for outbound traffic:
https://supportforums.cisco.com/message/4111294#4111294
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
5 Replies 5
Edison Ortiz
1) I highly suggest you edit your post and remove the public IP address information
2) Make sure to configure DNS Client in your server. Are you able to ping 8.8.8.8 from the server? If so, internet from the server is working. It's not able to resolved names due to lack of DNS configuration..
Thanks Edison for the reply.
That is not actuality not my ip address information just used it for illustrative purposes. I am not even able to ping 8.8.8.8 from my server all the packets are lost along the way.
Andrew,
HTH,
John
Thanks John that worked!
Awesome Thank you for letting us know!
HTH,
John
