Can't ping PCs across two cisco 2811 routers with L2TPv3 with xConnect on subinterface
Eyad Zorob
I have two cisco 2811 (Version 15.1(4)M3) connected using cross-over cable with two PCs connected on the outside interfaces (Windows 7 - firewall disabled).
PC1<-----Rj-45------>Fa0/0(R1)Fa0/1<---cross-over------->F0/1(R2)Fa0/0<-------------Rj-45---->PC2
Setting up L2TPv3 across two routers worked fine and tunnel session was running perfectly. Able to ping PC1 to PC2 and back
Now,
I changed it to sub-interface becasue I need to add a 3rd cisco 2811 router (R1 to R2 and R1 to R3) and the above setup does not work any more, show l2tunn session all :
Router1#show l2tun session all
L2TP Session Information Total tunnels 2 sessions 1
Session id 4140359334 is up, logical session id 32836, tunnel id 3777163427
  Remote session id is 1253026228, remote tunnel id 3141954740
  Locally initiated session
  Unique ID is 29
Session Layer 2 circuit, type is Ethernet Vlan, name is FastEthernet0/0.1:100
  Session vcid is 1001
  Interworking type is IP
  Circuit state is UP
    Local circuit state is UP
    Remote circuit state is UP
Call serial number is 1246500057
Remote tunnel name is Router2
  Internet address is 192.168.102.1
Local tunnel name is Router1
  Internet address is 192.168.103.1
IP protocol 115
  Session is L2TP signaled
  Session state is established, time since change 00:27:16
    0 Packets sent, 1632 received
    0 Bytes sent, 68544 received
  Last clearing of counters never
  Counters, ignoring last clear:
    Receive packets dropped:
      out-of-order:             0
      other:                    0
      total:                    0
    Send packets dropped:
      exceeded session MTU:     0
      other:                    0
      total:                    0
  DF bit off, ToS reflect disabled, ToS value 0, TTL value 255
  Sending UDP checksums are disabled
  Received UDP checksums are verified
  No session cookie information available
  FS cached header information:
    encap size = 24 bytes
    45000014 00000000 ff736d23 c0a86701
    c0a86601 4aafa9b4
  Sequencing is off
  Conditional debugging is disabled
  SSM switch id is 4109, SSM segment id is 12315
here is configuration output:
Using 2165 out of 245752 bytes
! Last configuration change at 18:15:46 UTC Sat Mar 3 2012
version 15.1
hostname Router1
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ipv6 cef
l2tp-class apple
authentication
password XXXXX
l2tp-class orange
authentication
password XXXXX
voice-card 0
license udi pid CISCO2811 sn XXXXXXXXXXXXXX
username SSSSSSSSSSSSS privilege 15 password 0 XXXXXXXXXXX
redundancy
pseudowire-class xconnect-apple
encapsulation l2tpv3
interworking ip
protocol l2tpv3 apple
ip local interface Loopback0
pseudowire-class xconnect-orange
protocol l2tpv3 orange
ip local interface Loopback1
interface Loopback0
ip address 192.168.103.1 255.255.255.0
interface Loopback1
ip address 192.168.105.1 255.255.255.0
interface FastEthernet0/0
no ip address
duplex auto
speed auto
no keepalive
interface FastEthernet0/0.1
encapsulation dot1Q 100
xconnect 192.168.102.1 1001 encapsulation l2tpv3 pw-class xconnect-apple
interface FastEthernet0/0.2
encapsulation dot1Q 200
xconnect 192.168.104.1 2002 pw-class xconnect-orange
interface FastEthernet0/1
ip address 192.168.101.1 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 192.168.102.1 255.255.255.255 192.168.101.2
ip route 192.168.104.1 255.255.255.255 192.168.101.3
access-list 1 permit any
access-list 100 permit icmp any any
access-list 199 permit ip any any
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Hi Eyad,
Can you explain what you did to resolve your issue?
I have a similar problem.
I am using two 2811's, each with a 16 port etherswitch module. I have a VLAN trunk configured between the 2811 and the etherswitch module. The two 2811's are connected via an E1 crossover. I have a client PC connected to an etherswitch module on each end (VLAN 30). My L2tpv3 tunnel is up, However I am unable to ping between my client PCs.
Any help will do,
Thanks.
Anwar
5 Replies 5
Peter Paluch
Hi Eyad,
Configuring the xconnect on a VLAN subinterface means that only the frames that enter the physical interface tagged with the appropriate VLAN tag will be tunneled across L2TP pseudowire to the other end. I do not believe this is what you want to achieve. Remember that the interface on which the xconnect is configured is facing the customer device. By configuring the xconnect on a VLAN subinterface, you expect that the customer device (in your case, a PC) sends and receives appropriately tagged frames. That is, in your case, certainly not happening. Also keep in mind that what is tunneled (in this case, tagged frames) has absolutely no relation through what it is tunneled (another Ethernet, PPP, HDLC, whatever) because it is L2TP+UDP+IP encapsulated.
Can you draw a diagram of the network as you expect it to be connected and tunneled when all three routers are present?
Best regards,
Peter
Thanks Peter for your help. I discovered it was a switch mis-match configurations mainly with cat2900Xl and 2950
Hi Eyad,
Any help will do,
Thanks.
Anwar
for my configuration, I used two 2900XL switches behind two 2811 rotuers. I needed to enable
encapsulation on each sub-interface on 2811s with matching vlan-ids:
encapsulation dot1Q vlan-id  native
on corresponding switch:
interface GigabitEthernet0/2
switchport trunk allowed vlan-id
switchport mode trunk
interface GigabitEthernet0/3
switchport access vlan vlan-id
switchport mode access
and client connected to port 3 on switch.
hope that will help.
Hi everybody,
I think I have the same problem as you but my platform  doesn't  works very well.
This is my platform configuration
I have a catalyst 3750 and a routeur 2811 on Paris
I have a catalyst 3550 and a router  2811 on Lyon
3750PAR --- --- 2811PAR ----- Tunnel L2TPV3---------2811 MPLS -----tunnel L2TPV3-------2811LYO-------trunk--3550LYO
Below the configuration files that I put on router 2811PAR
interface FastEthernet0/0.10
encapsulation dot1Q 10 native
no cdp enable
xconnect 10.0.1.249 10 pw-class ADMIN
interface FastEthernet0/0.20
no cdp enable
xconnect 10.0.2.250 20 pw-class CRON
interface FastEthernet0/0.30
encapsulation dot1Q 30
no cdp enable
here the configuration file  on 3750PAR
int fa1/0/22
switchport trunk envapsulation dot1Q
switchport trunk allowed vlan 10,20,30
switchport trunk native vlan 10
ip arp inspection trust
ip dhcp snooping trust
Here the problem. When I put the command line xconnect on sub interface  on router 2811PAR, I lost communication with the switch 3750PAR. If I delete the command line xconnect, data work well between router 2811PAR an switch 3750PAR.
Does someone has an idea to solve this problem?
