FPM on IOS Router
ugot2nome
Jedi:
In my example listed below, two IOS routers (R1 Fa0/1 IP:192.168.100.1/24 <----> R2 Fa0/1 IP:192.168.200.2/24) are directly connected.
The FPM service policy is applied to R1's Fa0/1 interface in the inbound direction.
Using FPM, I am trying to drop telnet traffic sourced from R2's Fa0/1 IP to R1's Fa0/1 IP.
Using FPM, I am trying to drop ICMP traffic sourced from R2's Fa0/1 IP to R1's Fa0/1 IP; if the size is greater than 1500.
I am able to accomplish this task if I use each policy individually. When combining both requirements neither policy is coming into effect. I am unsure if it is the nature of the beast or a misconfiguration or an IOS bug. If someone can please comment/suggest alternatives, I will be glad to try it. Thanks in advance for your help.
R1
R1#sh ver
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
System image file is "flash:c2800nm-advipservicesk9-mz.124-24.T4.bin"
Cisco 2811 (revision 53.50) with 249856K/12288K bytes of memory.
Configuration
load protocol system:fpm/phdf/ip.phdf
load protocol system:fpm/phdf/icmp.phdf
load protocol system:fpm/phdf/tcp.phdf
class-map type stack match-all S_TELNET
match field IP protocol eq 0x6 next TCP
class-map type stack match-all S_ICMP
match field IP protocol eq 0x1 next ICMP
class-map type access-control match-all AC_C_TELNET
match field IP source-addr eq 192.168.200.2
match field IP dest-addr eq 192.168.200.1
match field TCP dest-port eq 23
class-map type access-control match-all AC_C_ICMP
match field ICMP type eq 8
match field IP flags eq 1
policy-map type access-control AC_P_ICMP
class AC_C_ICMP
   drop
policy-map type access-control AC_P_TELNET
class AC_C_TELNET
   drop
policy-map type access-control FPM          (WORKS)
class S_ICMP
  service-policy AC_P_ICMP
OR
class S_TELNET
  service-policy AC_P_TELNET
OR
policy-map type access-control FPM          (NEITHER ONE WORKS)
class S_ICMP
class S_TELNET
interface fa0/1
service-policy type access-control input FPM
ugot2nome
Bump....Any takers on this? Anybody from Cisco knows the answer?
