Can't ping Switch from PC (using VLANS)
Gugolsan
Hello, I'm using Cisco Packet Tracer and trying to configure VLANs and routing between them. Here are two tables, which I have used for configuring:
Device
Interface
IP address
Subnet mask
Default gateway
R1
G0/1.1
192.168.1.1
255.255.255.0
G0/1.10
192.168.10.1
255.255.255.0
G0/1.20
192.168.20.1
255.255.255.0
Lo0
209.165.200.225
255.255.255.224
S1
VLAN 1
192.168.1.11
255.255.255.0
192.168.1.1
S2
VLAN 1
192.168.1.12
255.255.255.0
192.168.1.1
PC-A
Fa0
192.168.10.3
255.255.255.0
192.168.10.1
PC-B
Fa0
192.168.20.3
255.255.255.0
192.168.20.1
PC-F
Fa0
192.168.20.2
255.255.255.0
192.168.20.1
PC-S
Fa0
192.168.10.2
255.255.255.0
192.168.10.1
PortsAttachmentNet
S1 F0/1
802.1Q Trunk
N/A
S2 F0/1
802.1Q Trunk
N/A
S1 F0/5
802.1Q Trunk
N/A
S1 F0/2
VLAN 20 – Faculty
192.168.20.0/24
S2 F0/2
VLAN 10 – Students
192.168.10.0/24
S1 F0/6
VLAN 10 – Students
192.168.10.0/24
S2 F0/18
VLAN 20 – Faculty
192.168.20.0/24
My ,pkt file looks like:
I have connected and customized devices, customized VLANs and trunks on switches, customized routing between VLAN based on trunk. Then I have been pinging from PC-A to gateway VLAN 10 with address 192.168.10.0, from PC-A to PC-B, from PC-A to Lo0, from PC-F to PC-S and from PC-S to S2. Everything has been succeded except last: ping from PC-S to switch S2. Where can be the problem? Any ideas?
38 Replies 38
in SW1 and SW2 config trunk native VLAN to be VLAN 1
This is bad for safety, if I don't want to config like that?
sorry I dont get what you mean ?
I have done these commands for S1 cause I need actually native VLAN to be VLAN123:
S1(config)#int range fa0/1,fa0/5
S1(config-if-range)#switchport trunk native vlan 123
S1(config-if-range)#switchport trunk allowed vlan 1,10,20,123
The similar thing is needed for S2 too.
it will not work, VLAN in router native is different than native vlan in SW.
you must match it.
So what should I fix then? You said that trunk native VLAN for Switches should be VLAN1, I need VLAN123 for that thing. Should I change something in Router configuration?
if you want to use VLAN 123 as native VLAN then
1-remove VLAN1 and assign IP you use before for VLAN1 for VLAN 123 in both SW1 & SW2
2- in router remove G0/1.1 and config new subinterface g0/1.123 as native, and use same IP
Thank you so much, forgot about native...
You are so so welcome
