Can't ping Switch from PC (using VLANS)
Gugolsan
Hello, I'm using Cisco Packet Tracer and trying to configure VLANs and routing between them. Here are two tables, which I have used for configuring:
Device
Interface
IP address
Subnet mask
Default gateway
R1
G0/1.1
192.168.1.1
255.255.255.0
G0/1.10
192.168.10.1
255.255.255.0
G0/1.20
192.168.20.1
255.255.255.0
Lo0
209.165.200.225
255.255.255.224
S1
VLAN 1
192.168.1.11
255.255.255.0
192.168.1.1
S2
VLAN 1
192.168.1.12
255.255.255.0
192.168.1.1
PC-A
Fa0
192.168.10.3
255.255.255.0
192.168.10.1
PC-B
Fa0
192.168.20.3
255.255.255.0
192.168.20.1
PC-F
Fa0
192.168.20.2
255.255.255.0
192.168.20.1
PC-S
Fa0
192.168.10.2
255.255.255.0
192.168.10.1
PortsAttachmentNet
S1 F0/1
802.1Q Trunk
N/A
S2 F0/1
802.1Q Trunk
N/A
S1 F0/5
802.1Q Trunk
N/A
S1 F0/2
VLAN 20 – Faculty
192.168.20.0/24
S2 F0/2
VLAN 10 – Students
192.168.10.0/24
S1 F0/6
VLAN 10 – Students
192.168.10.0/24
S2 F0/18
VLAN 20 – Faculty
192.168.20.0/24
My ,pkt file looks like:
I have connected and customized devices, customized VLANs and trunks on switches, customized routing between VLAN based on trunk. Then I have been pinging from PC-A to gateway VLAN 10 with address 192.168.10.0, from PC-A to PC-B, from PC-A to Lo0, from PC-F to PC-S and from PC-S to S2. Everything has been succeded except last: ping from PC-S to switch S2. Where can be the problem? Any ideas?
2 Accepted Solutions
in SW1 and SW2 config trunk native VLAN to be VLAN 1
if you want to use VLAN 123 as native VLAN then
1-remove VLAN1 and assign IP you use before for VLAN1 for VLAN 123 in both SW1 & SW2
2- in router remove G0/1.1 and config new subinterface g0/1.123 as native, and use same IP
38 Replies 38
post your zipped Packet Tracer project (.pkt) file...
Have you seen my attached file? Any suggestions?
I have forgot about passwords: for S1 and S2 - ciscoVLAN and class311, for R1 - ciscoRoute and class311
Gugolsan
Hello, i attached zip with .pkt here
check the VLAN in both SW1 and SW2 and if some is missing then add it.
I have checked and results seem good:
can you show me the config of interface g0/1 in Router ?
Here it is:
are
for all PC in VLAN 10 config the GW to be 192.168.10.1 (subinterface in router) ??
for all PC in VLAN 20 config the GW to be 192.168.20.1 (subinterface in router ) ??
Yes, it is like this. PC-A and PC-S have 192.168.10.1 and PC-B and PC-F 192.168.20.1.
OK,
add another PC in both SW and assign VLAN1 to port connect these new PC.
What do you mean by assign VLAN1?
SW1-PC
SW1 use port x/x to connect PC
config port x/x as following
interface x/x
switchport access vlan 1
Done for both PCs: PC0 and PC1. Now it looks like this:
