Can't ping Switch from PC (using VLANS)
Gugolsan
Hello, I'm using Cisco Packet Tracer and trying to configure VLANs and routing between them. Here are two tables, which I have used for configuring:
Device
Interface
IP address
Subnet mask
Default gateway
R1
G0/1.1
192.168.1.1
255.255.255.0
G0/1.10
192.168.10.1
255.255.255.0
G0/1.20
192.168.20.1
255.255.255.0
Lo0
209.165.200.225
255.255.255.224
S1
VLAN 1
192.168.1.11
255.255.255.0
192.168.1.1
S2
VLAN 1
192.168.1.12
255.255.255.0
192.168.1.1
PC-A
Fa0
192.168.10.3
255.255.255.0
192.168.10.1
PC-B
Fa0
192.168.20.3
255.255.255.0
192.168.20.1
PC-F
Fa0
192.168.20.2
255.255.255.0
192.168.20.1
PC-S
Fa0
192.168.10.2
255.255.255.0
192.168.10.1
PortsAttachmentNet
S1 F0/1
802.1Q Trunk
N/A
S2 F0/1
802.1Q Trunk
N/A
S1 F0/5
802.1Q Trunk
N/A
S1 F0/2
VLAN 20 – Faculty
192.168.20.0/24
S2 F0/2
VLAN 10 – Students
192.168.10.0/24
S1 F0/6
VLAN 10 – Students
192.168.10.0/24
S2 F0/18
VLAN 20 – Faculty
192.168.20.0/24
My ,pkt file looks like:
I have connected and customized devices, customized VLANs and trunks on switches, customized routing between VLAN based on trunk. Then I have been pinging from PC-A to gateway VLAN 10 with address 192.168.10.0, from PC-A to PC-B, from PC-A to Lo0, from PC-F to PC-S and from PC-S to S2. Everything has been succeded except last: ping from PC-S to switch S2. Where can be the problem? Any ideas?
38 Replies 38
ping from PC-S to SVI VLAN1 in SW1 and SW2, are ping success ??
No, I have used ping 192.168.1.11 and 192.168.1.12. In both cases request timeout.
last commend
add below command in both SW (SW1 & SW2)
ip default-gateway 192.168.1.1
Done.
it ping now ?
Unfortunately, not, maybe you can take a look by yourself using my .pkt file? Maybe you will see something missing?
the file is not open ,
one more thing PC-S connect to SW2 port, are the port assign with VLAN 10?
What do you mean not open? Yes, there are allowed VLAN 1,10,20,123 and the port is assign with VLAN 20.
assing with VLAN 20 but some PC like PC-A and PC-S must assing to VLAN 10
can you copy paste the config of SW and router here ?
I have pasted previously two times, but it has dissappered...
S1:
Building configuration...
Current configuration : 1542 bytes
version 15.0
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname S1
enable secret 5 $1$mERr$zHnlwK/VLygd7R8v28o.s.
no ip domain-lookup
spanning-tree mode pvst
interface FastEthernet0/1
switchport trunk native vlan 123
switchport trunk allowed vlan 1,10,20,123
switchport mode trunk
interface FastEthernet0/2
switchport access vlan 20
switchport mode access
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
switchport access vlan 10
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.1.11 255.255.255.0
line con 0
password ciscoVLAN
logging synchronous
login
line vty 0 4
login
line vty 5 15
login
end
S2:
Current configuration : 1466 bytes
version 15.0
hostname S2
no ip domain-lookup
switchport nonegotiate
interface Vlan1
ip address 192.168.1.12 255.255.255.0
line con 0
password ciscoVLAN
logging synchronous
login
line vty 0 4
login
line vty 5 15
login
end
Native vlan in sw trunk is vlan 123 and it in router vlan1?
That sure issue here.
How can then i fix it?
