Can't resolve names via ping/traceroute even with domain lookup enabled
Jim Mueller
We are trying to enable domain lookups for ping & traceroute from our remote routers. A mildly scrubbed version of our running config is below.
- Added 'ip domain lookup source-interface FastEthernet8', neither ping nor traceroute resolves IP's
- Added 'ip domain-server 4.2.2.2', no change
- Changed it to 'ip domain lookup source-interface VL1',no change
- Added 'ip host GTEDNS 4.2.2.2' and then I was able to 'ping GTEDNS' successfully
- Added permits for UDP/TCP to/from any/any eq DNS to internet-in-v2 ACL, removed and reapplied the deny, no change
- Removed the deny from the internet-in-v2 ACL, no change
What are we missing?
---snip---
version 15.0
no service pad
service tcp-keepalives-in
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
service compress-config
hostname fl2020-vpn001
boot-start-marker
boot-end-marker
logging buffered 4096
logging console critical
no aaa new-model
clock timezone EST -5
clock summer-time EDT recurring
ip source-route
ip cef
ip flow-cache timeout active 1
no ip bootp server
no ip domain lookup
ip domain name ourdomain.com
no ipv6 cef
license udi pid CISCO891-K9 sn **********
vtp mode transparent
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 5
crypto isakmp policy 10
encr 3des
group 5
crypto isakmp key ***** address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 600
crypto ipsec transform-set esp-3des-sha-trans esp-3des esp-sha-hmac
mode transport
no crypto ipsec nat-transparency udp-encaps
crypto ipsec profile DMVPN
set transform-set esp-3des-sha-trans
set pfs group5
interface Loopback0
ip address 10.1.1.2 255.255.255.255
interface Tunnel1
bandwidth 1536
ip address 172.18.1.83 255.255.252.0
no ip redirects
ip mtu 1400
ip nhrp authentication *****
ip nhrp map multicast a.b.217.11
ip nhrp map 172.18.0.1 a.b.217.11
ip nhrp network-id 1
ip nhrp holdtime 300
ip nhrp nhs 172.18.0.1
ip tcp adjust-mss 1360
ip policy route-map df-bit-clear
qos pre-classify
tunnel source FastEthernet8
tunnel mode gre multipoint
tunnel key 1
tunnel path-mtu-discovery
tunnel protection ipsec profile DMVPN shared
interface Tunnel2
bandwidth 768
ip address 172.18.5.83 255.255.252.0
no ip redirects
ip mtu 1400
ip nhrp map 172.18.4.1 c.d.158.52
ip nhrp map multicast c.d.158.52
ip nhrp network-id 2
ip nhrp nhs 172.18.4.1
qos pre-classify
tunnel key 2
interface FastEthernet0
no cdp enable
interface FastEthernet1
no cdp enable
interface FastEthernet2
no cdp enable
interface FastEthernet3
no cdp enable
interface FastEthernet4
no cdp enable
interface FastEthernet5
no cdp enable
interface FastEthernet6
no cdp enable
interface FastEthernet7
no cdp enable
description Comcast
bandwidth 8192
ip address e.f.154.5 255.255.255.252
ip access-group internet-in-v2 in
ip nbar protocol-discovery
ip flow ingress
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Vlan1
description Inside Private Network
ip address 10.20.20.1 255.255.255.192
ip helper-address 192.168.0.12
no ip redirects
ip flow ingress
ip tcp adjust-mss 1400
interface Async1
no ip address
encapsulation slip
async mode interactive
router eigrp 111
network 10.20.20.0 0.0.0.63
network 172.18.0.0
passive-interface default
no passive-interface Tunnel2
no passive-interface Tunnel1
eigrp stub connected
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
ip flow-export source Vlan1
ip flow-export version 9 peer-as
ip flow-export destination 192.168.0.105 2055
ip route 0.0.0.0 0.0.0.0 e.f.154.6
ip access-list extended internet-in-v2
permit esp any host e.f.154.5
permit udp any eq isakmp host e.f.154.5 eq isakmp
permit icmp any host e.f.154.5 echo
permit icmp any host e.f.154.5 echo-reply
permit tcp any host e.f.154.5 eq 22
permit udp host 130.126.24.53 host e.f.154.5 eq ntp
permit udp host 198.82.162.213 host e.f.154.5 eq ntp
deny ip any any log
access-list 10 permit 192.168.0.105
access-list 10 permit 172.16.26.0 0.0.0.255
access-list 10 deny any
access-list 15 permit 192.168.0.5
access-list 15 deny any
no cdp run
route-map df-bit-clear permit 10
set ip df 0
control-plane
privilege exec level 15 connect
privilege exec level 15 telnet
privilege exec level 15 rlogin
privilege exec level 15 show ip access-lists
privilege exec level 1 show ip
privilege exec level 15 show access-lists
privilege exec level 15 show logging
privilege exec level 10 debug
privilege exec level 2 clear line
line con 0
login local
line 1
login local
modem InOut
modem autoconfigure discovery
transport input all
autoselect ppp
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
login local
line vty 0 4
access-class telnet-in in
privilege level 15
login local
transport input telnet
line vty 5 15
access-class ssh-in in
privilege level 15
login local
transport input ssh
scheduler max-task-time 5000
ntp server 130.126.24.53
ntp server 198.82.162.213
end
---snip---
15 Replies 15
John Blakley
I had originally posted to add dns support to your acl, but then I reread your intro and noticed that you had already tried that. Do you have anything in the logs indicating what could be blocked? Have you tried removing the acl to see if that resolves the issue? Removing the deny at the end won't help because you don't have a permit any to catch the implicit deny, so all of your traffic that doesn't match the previous lines would still be denied.
Also, do you have anything in front of the router like a firewall, or does this connect directly to the provider's equipment?
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
What supporting commands do I need, just these?
ip domain-lookup [Do I need to specify the interface?]
ip name-server 4.2.2.2
This is what I did, and there is no change:
---snip---
fl2020-vpn001#
fl2020-vpn001#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
fl2020-vpn001(config)#ip domain-lookup
fl2020-vpn001(config)#ip name-server 4.2.2.2
fl2020-vpn001(config)#ip access-list extended internet-in-v2
fl2020-vpn001(config-ext-nacl)#
fl2020-vpn001(config-ext-nacl)#permit udp any any eq 53
fl2020-vpn001(config-ext-nacl)#no deny ip any any log
fl2020-vpn001(config-ext-nacl)#deny ip any any log
fl2020-vpn001(config-ext-nacl)#end
fl2020-vpn001#ping www.cnn.com
Translating "www.cnn.com"...domain server (4.2.2.2)
% Unrecognized host or address, or protocol not running.
fl2020-vpn001#ping www.yahoo.com
Translating "www.yahoo.com"...domain server (4.2.2.2)
fl2020-vpn001#traceroute www.yahoo.com
% Unrecognized host or address.
fl2020-vpn001#
---snip---
You're concerned with the return traffic coming back in on 53 as well, so try adding these two lines:
permit udp any eq 53 any
HTH,
John
Clearly the most recent output shows that the router is attempting to resolve names using 4.2.2.2 as the name server. The fact that the names do not resolve suggests that the responses are being blocked. I would like to see a fresh copy of the access list. And perhaps the output of traceroute 4.2.2.2 to verify reachability and what path gets to the name servers might be helpful.
Rick
Rick
Jim Mueller
Current ACL:
---snip---
permit udp any any eq domain
permit udp any eq domain any
deny   ip any any log
---snip---
Current results, ping now works, traceroute not:
---snip---
Translating "www.cnn.com"...domain server (4.2.2.2) [OK]
Sending 5, 100-byte ICMP Echos to 157.166.249.11, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Translating "www.yahoo.com"...domain server (4.2.2.2) [OK]
Sending 5, 100-byte ICMP Echos to 98.139.180.149, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/72/96 ms
Tracing the route to ds-any-fp3-real.wa1.b.yahoo.com (98.139.180.149)
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *
---snip---
Try enabling icmp fully first to see if that resolves your issue...
permit icmp any any
Well, Alain beat me to it, but he's correct. Port-unreachable is what you're going to need.
HTH,
John
this is because you are only permitting icmp echo and echo-reply but Cisco uses udp traceroute and the return traffic shall be port-unreachable icmp message.
just do this:
91 permit icmp any host e.f.154.5 port-unreachable
Alain
Jim Mueller
Current ACL:
---snip---
permit icmp any any echo-reply
deny ip any any log
---snip---
Current results:
---snip---
Sending 5, 100-byte ICMP Echos to 98.139.183.24, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 52/97/184 ms
Tracing the route to ds-any-fp3-real.wa1.b.yahoo.com (98.139.183.24)
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7
---snip---
You're going to need to specify for any. Currently, you have it tied to one address to trace to:
permit icmp any any port-unreachable
HTH,
John
Jim Mueller
Current ACL:
---snip---
deny   ip any any log
---snip---
Current results:
---snip---
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/62/92 ms
  1  *  *  *
  2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *  *  *
  7  *  *  *
  8  *  *  *
  9  *  *  *
10  *  *  *
11
fl2020-vpn001#
---snip---
You're resolving it....do you have anything between you and your ISP equipment? Firewall?
HTH,
John
Jim Mueller
I forgot to answer some of your questions earlier...
* The last entries were at 11:39 (about 15 minutes ago), where icmp was denied. Current traceroute isn't adding any new entries.
Do you have anything between you and your ISP equipment? Firewall?
* No, the WAN port is directly attached to (one of) the LAN port(s) on the ISP modem
* I just tried this... removing the ACL from Fa8 and traceroute works perfectly, but we can't leave it off so I've re-enabled it after this test:
---snip---
fl2020-vpn001(config)#int fa8
fl2020-vpn001(config-if)#no ip access-group internet-in-v2 in
fl2020-vpn001(config-if)#end
  1 10.1.10.1 0 msec 4 msec 0 msec
  2 73.11.36.1 72 msec 16 msec 12 msec
  3 te-9-2-ur01.miccosukeerd.fl.tallah.comcast.net (68.87.161.69) 12 msec 12 msec 8 msec
  4 te-4-1-ur01.timberlanerd.fl.tallah.comcast.net (68.85.236.62) 12 msec 20 msec 8 msec
  5 te-6-4-ar01.l3-tallahas.fl.northglf.comcast.net (68.85.236.101) 12 msec 32 msec 12 msec
  6 te-2-0-0-8-cr01.56marietta.ga.ibone.comcast.net (68.86.95.5) 52 msec 36 msec 40 msec
  7 64.209.97.13 24 msec 16 msec 16 msec
  8 te4-3-10G.ar8.NYC1.gblx.net (67.16.143.26) 36 msec
    po1-20G.ar8.NYC1.gblx.net (67.16.137.94) 36 msec
    po2-10G.ar8.NYC1.gblx.net (67.16.137.98) 36 msec
  9 64.215.30.22 44 msec 68 msec 68 msec
10 ae-3.pat2.bfz.yahoo.com (216.115.97.209) 72 msec 80 msec 48 msec
11 ae-3.msr1.bf1.yahoo.com (216.115.100.29) 48 msec
    ae-4.msr1.bf1.yahoo.com (216.115.100.25) 52 msec
    ae-4.msr2.bf1.yahoo.com (216.115.100.73) 64 msec
12 xe-4-0-0.clr1-a-gdc.bf1.yahoo.com (98.139.232.81) 76 msec
    UNKNOWN-98-139-129-X.yahoo.com (98.139.129.183) 52 msec
    xe-9-0-0.clr2-a-gdc.bf1.yahoo.com (98.139.232.105) 48 msec
13 et-17-1.fab2-1-gdc.bf1.yahoo.com (98.139.128.39) 72 msec
    et-18-25.fab8-1-gdc.bf1.yahoo.com (98.139.128.67) 68 msec
    et-17-1.fab5-1-gdc.bf1.yahoo.com (98.139.128.45) 60 msec
14 po-12.bas1-7-prd.bf1.yahoo.com (98.139.129.193) 68 msec
    po-11.bas2-7-prd.bf1.yahoo.com (98.139.129.179) 52 msec
    po-11.bas1-7-prd.bf1.yahoo.com (98.139.129.177) 72 msec
15  *  *  *
16  *  *  *
17  *  *  *
18  *  *  *
19  *  *  *
20
fl2020-vpn001#
---snip---
can you permit time-exceeded and unreachable too:
10 permit icmp any any time-exceeded
20 permit icmp any any unreachable
Alain
Bam! Now that wasn't so difficult was it So for the record, these were the changes... do I need both UDP permits, as they seem to be very similar?
conf t
ip domain-lookup
deny   ip any any log
