can the next-hop in pbr be not directly connected?
ino
i have a c1111 router and a c2960x with routing enabled
an lte router is connected to the c1111
0.0.0.0 on the c2960x is to the c1111
on the c1111 i do set the next-hop with a route map to the lte routers ip
that works fine
my question is
if i connect the lte router to the c2960 but want traffic still first go through the c1111 can i do that?
so currently traffic goes
device --> c2960 --> c1111 --> lte
what i want (repluging the lte to the c2960)
device --> c2960 --> c1111 --> c2960 --> lte
would simply setting the next-hot on the c1111 to the lte router work or not as it isnt truly the next hop as traffic first needs to go to the 2960
i probably could do it by setting the next hop to the c2960 and marking it and marked traffic would then be send from the c2960 to the lte router it would be just a bit cumbersome
Sure it can,
And you can also use verify reachability via ip sla.
Hello
Why do you even need PBR given the setups you have outlined, in either case the 2960 are l2 access switchs with no routing, it the second setup the connection between the rtr and the LTE will just be a Layer2 access port.
Kind Regards
Paul
ino
@MHM Cisco World thanks a brief test seems to show it will work
that currently it didn't (a trace dies at the lte) is probably because the lte isnt set up correctly in the moment havent got time for it till now
this next-hop is some what confusing to me lets assume i have R1-R2-R3 after each other
pinging R2 from R1 will go R1-R2 job done
what if i set the next-hop to R3? will it go R1-R2-R3-R2?
@paul driver the c2960 although not a fully blown L3 router it is capable of L3 routing (i extra mentioned that its turned on)
the c1111 has a build in lte which i use for vpn
the original plan was to have the second lte router pas through its lte to it and use both lte connections for internet traffic in a round robin manner
bit till now i wasnt able to achieve that no mater what i do if both lte are in the routing table the vpn breaks as it tries to send the responses from the wrong connection
i tried setting ip local policy route-map whit out any luck
any way current plan is to have 2X 2960
each with its own lte router connected to it and vpn access (non cisco lte dev)
and having the build in lte on the c1111 for vpn to that one
so all will have an out of band vpn connection for management in case
having some basic acl on the 2960 for known and expected traffic
anything else is going to the c1111 including all traffic to the internet
so devices connected to one 2960 could end up using the lte connected to the other 2960
