Can this switch be upgraded to a layer 3?
robcwilson1
WS-C2960X-48LPD-L Catalyst2960-X48 Gig EPoE
7 Replies 7
Mark Malone
No its pure layer 2 switch , only 2960s that can operate in layer2/3 are XR models
Thank you Mark.  That's what I thought.  How's the 2960XR model as a layer 3 switch?
Most my layer 3 switches are a lot more powerful I have had not got to use one so far but for a small network I cant see why they wouldn't work ok , they are limited though and they are the lowest end layer 3 switch you can buy with going SMB models
hers the data sheet on what they are capable of
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/data_sheet_c78-728232.html
For small remote sites or specific Layer 3 zone, it's working very fine. Below the cisco doc with its capabilities:
However if you want to use it as core switch for medium company or even big, it's not the right guy.
PS: Please don't forget to rate and mark as correct answer if this solved your issue
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
What do you mean by Layer 3?
This switch has a LAN Base image that allows some few L3 capabilities, like:
  1. static routes
  2. Interval routing
  3. HSRP
  4. IPv6 static routing
If you want to have dynamic routing protocol, you can't with this model. You need an IP lite image that's only available (if I remember good) with Cat 2960XR.
Hope that's answering your question.
Francesco
I'm looking to setup a core switch for a small network.  Need ability to inter vlan route and route to firewall and Vice versa.  I'm also putting about 30 PoE phones and 4 APs on it.  Will it have enough power for these devices?
the phones if there 15.4 watts standard 7942 your good it will only use 462 and you have 750 watts available just make sure the aps don't max out the rest,  check what poe they use per unit
