Can we assign multiple Vlans to same physical switch port-Access Port
ravi281278
We are having L2 Vlans on our switch and there is a requirement of assigning multiple VLANs to same physical switch port-Access port. We will be terminating server over this port having multiple applications.
31 Replies 31
Try using
Switchport access vlan 10
switchport voice vlan 20
under interface.
VLAN Name                             Status    Ports
1    default                          active    Et0/1, Et0/2, Et0/3, Et1/0
                                                Et1/1, Et1/2, Et1/3, Et2/0
                                                Et2/1, Et2/2, Et2/3, Et3/0
                                                Et3/1, Et3/2, Et3/3
10   VLAN0010                         active    Et0/0
20   VLAN0020                         active    Et0/0
Please do not hesitate to click the STAR button if you are satisfied with my answer.
