Can we configure multiple tunnel on single WAN Port?
r.makhija
Hello!
I have 3 IP networks connected to eachother thru VPN leaseline. And now i have to establish a parller wireless link for backup in case of failure. I just want to confirm. I need to tunnel router on each end and configure it to communicate with others. In this case of 3 locations, i need to tunnel up each router with 2 others. Can this be done whereas, all 3 networks on wireless link are connected in serial.
Hope to hear from you soon.
thanks!
Rahul
csco10716389
Yes u can associate your multiple tunnels with ur physical interface
thanks buddy!
Which router model do u suggest me to use?
Is 1841 fine for same?
