2811 cisco router issue
krishnautl
Sir
while checking the #show run command,through telnet, after getting two line output,balance i am not able to view,by pressing enter key and back space then also balance configuration is not coming.The router is like a hang stage.Then again i need to start a new telnet session to get in.
Is there any solution to solve this issue,so please respond this soon and give me a suitable answer
Thanking you
Krishnakumar.s
smothuku
Level 7
Level 7
Hi ,
What is the size of the IOMEM...
Change the size of the IOMEM and try...
Satish
